Floater or Fixed? - Mod to a pre-routed body - Jemsite
post #1 of 4 (permalink) Old 12-18-2000, 07:57 PM Thread Starter
I have an old Radius (still) Im working on, and can't decide if I should leave the Lo-Pro in it, or fill the cavity in and go with a fixed bridge.
I have a JPM, and a Jem (until it sells), so I figure for doing some low stuff (dropped D or C) I could use a shorter scale neck with a fixed bridge. *Anyone got any thoughts on filling in the trem cavity and putting a fixed bridge on the body?
tomizm is offline
post #2 of 4 (permalink) Old 12-18-2000, 08:34 PM
Floater or Fixed?
Anyone can correct me on this, but I'm pretty sure the Radius is a 25.5" scale.
It would be a lot easier to just block the trem. Filling can be a pain in the ars and ugly.
J>
Vaibanez is offline
post #3 of 4 (permalink) Old 12-18-2000, 09:17 PM
Floater or Fixed?
I'd agree with Jimm... just block the trem. It won't quite give you the same low-end “oomph” that you'll get from a fixed bridge (especially with the strings through the body), but it'll be easier and more versatile should you change your mind later.
Also, if you want to experiment with dropped tunings, you want a longer scale length, not a shorter one. The longer scale length (along with heavier strings) will give you added string tension which will help compensate for the “floppiness” you get when you drop the tuning.
Warmoth makes baritone retrofit necks that fit 25.5´´ scale length guitars like your Radius. They have 27´´ scale lengths.
darren wilson is offline
post #4 of 4 (permalink) Old 12-21-2000, 02:06 PM
Floater or Fixed?
They did make a fixed bridge S, with the Les Paul tune-o-matic type bridge. I see them sometimes on eBay, maybe that's what you should be looking in to.
And I do believe the S's and R's are 25.5.
Doink is offline
fixed bridge , les paul , scale lengths , string tension
WTB Strat Guitar Body Rear Routed.. HoosierDaddy Classified Ads: Guitars and Gear 0 12-16-2012 04:47 PM
WTB Rear routed Jem style body AANJ (EU) Ad_Astra Classified Ads: Guitars and Gear 2 05-23-2012 01:18 PM
What is the difference between front routed and rear routed? ironfistx All Other Guitars (including Prestige) 9 04-06-2012 08:03 PM
Can a pickup be cleanly routed into a finished body? (pic) superhairycamel Tech: Setup, Repairs and Mods 11 12-23-2008 10:27 PM
WTB: AANJ MIJ Front Routed RG Body caprile Classified Ads: Guitars and Gear 0 06-29-2008 06:43 PM
