Floyd rose bridge saddle block inserts compatible with Edge trem? - Jemsite
post #1 of 10 (permalink) Old 08-06-2011, 04:38 PM Thread Starter
I lost a saddle block and ordered a new set from Allparts, labeled Floyd Rose. At a glance it appears these blocks are a smidge taller than those that came with my Edge (which edge? I don't know; it's a 1995 RG520QS).
I've noticed the string with the replaced block (B string) is sitting a bit higher than the others. Is this because I have the wrong part?
Also, is the indented circle supposed to be at the top or bottom, if the guitar is lying flat on its back? I surmised that it should be towards the top, but may be wrong.
Thanks all.
-the Gaucho
gauchosilvertone is offline
post #2 of 10 (permalink) Old 08-06-2011, 09:17 PM
Re: Floyd rose bridge saddle block inserts compatible with Edge trem?
I just installed a new Gotoh tremolo and compared the blocks to the old Lo TRS II that came out. They looked very close in size. On both of these tremolos, the circles were definitely toward the bottom. They should line up with where ever the screws that lock them down will be hitting the block.
gideond is offline
post #3 of 10 (permalink) Old 08-06-2011, 09:45 PM Thread Starter
Thanks for the reply, gideond. I knew the screws should seat into the circles, but the things are so tiny it's tough to tell just where the screw is hitting the insert. If only I had x-ray vision.
That does make me feel better that maybe the slight size difference shouldn't matter, as long as the screw is seating into the insert properly.
post #4 of 10 (permalink) Old 08-31-2011, 07:39 PM Thread Starter
So I've turned the saddle insert around so that the recessed circle is towards the bottom (towards the body of the guitar), and still my B string sits marginally higher than its neighbors. Not excessively so, but just enough that I can feel it and it bothers me. I'm thinking I'll go ahead and replace the other 5 and see if they all line up right (or rather just replace one next to it to see if the two new ones are in line).
Any other experience or thoughts on this?
the Gaucho
post #5 of 10 (permalink) Old 09-01-2011, 07:03 AM
I'd replace them all. If it doesn't feel right then you won't be happy until you go ahead and swap them out.
gideond is offline
post #6 of 10 (permalink) Old 09-01-2011, 08:35 AM
Reviews: 13
From my understanding the blocks are apparently unique to the Edge Trem system. Replacements aren't too hard to get, however they can be expensive to replace with an original part - beleive me, I was stupid enough to buy some. Try Rich he may have them, and likely at a cheaper price than from were I bought mine.
-Wolfram
Wolfram is offline
post #7 of 10 (permalink) Old 09-02-2011, 10:48 AM
Don't forget that OFR saddles have a tiny "L" on the bottom and you'll have to sand that down. It's pretty easy, 10 seconds for each, but if you don't do that, the bottom won't be totally flat.
tearsx is offline
post #8 of 10 (permalink) Old 09-03-2011, 11:51 AM Thread Starter
MYSTERY SOLVED.
Amazing what happens when you do a little detecitve work.
I noticed the high E insert was sitting lower than the rest, which was making it feel like the B was higher. I fully removed the E saddle and found that part of it is missing- the thin metal backing that should cradle the saddle insert is simply missing. Thus the insert was sitting on the base of the trem itself (I'm using the word "base" loosely since I don't know that much about floating trems).
I don't have another saddle on hand of course so I just carefully made sure the screw was seating directly into the recessed hole in the saddle insert (tougher than it sounds) and it seems that is holding it in place where it should be, and fixing my string unevenness problem.
Next step I guess is to contact Rich to get me a new saddle.
Thanks all- I've learned a lot through this thread even though it turned out to be a simple problem.
-the Gaucho
post #9 of 10 (permalink) Old 09-03-2011, 11:56 AM Thread Starter
MYSTERY SOLVED.
-the Gaucho
post #10 of 10 (permalink) Old 09-03-2011, 12:00 PM Thread Starter
As for ordering the part, which saddle should go on my RG520QS Edge tremolo? What's the difference between the Edge Black "Bare" and the Edge Black "Complete?
edge , floyd rose , saddle blocks , saddle inserts
WTB: Need bridge saddle for a ibanez edge III trem guitarscott Classified Ads: Guitars and Gear 0 05-03-2011 08:27 PM
FT: Floyd Rose Brass Trem Block for Ibanez Edge Block t1r12003 Classified Ads: Guitars and Gear 0 02-27-2009 08:19 PM
Js1000 bridge saddle inserts: $$ and availability? Sendmorecops666 Ibanez JEM, UV, JS & Other Signature Models 1 10-16-2005 06:13 PM
floyd rose studs compatible with edge stud screws jpascual Tech: Setup, Repairs and Mods 1 04-08-2005 10:25 PM
saddle inserts on 2003 edge pro jeffrg270 Tech: Setup, Repairs and Mods 4 01-16-2004 05:07 PM
