Floyd Rose Original or Floyd Rose Pro - Jemsite
post #1 of 9 (permalink) Old 09-06-2011, 03:54 PM Thread Starter
Hi, I'm asking a few questions before buying the parts for my custom made guitar, one of the questions I have is which tremolo should I got, FLoyd Rose Pro or Floyd Rose Original?
I'm asking this for the original one not the licensed one.
enb141 is offline
post #2 of 9 (permalink) Old 09-07-2011, 09:36 AM
Reviews: 6
Re: Floyd Rose Original or Floyd Rose Pro
I'd lean towards the OFR -- the Pro has narrower string spacing, and OFR parts are easier to get.
Philboski is offline
post #3 of 9 (permalink) Old 09-07-2011, 03:35 PM Thread Starter
so the Floyd Rose Pro will need pickups with no F-spacing?
enb141 is offline
post #4 of 9 (permalink) Old 09-08-2011, 09:45 AM
Reviews: 6
Couldn't tell you about the F-spacing. Here's a page that outlines some details:
http://www.floydrose.com/bridges/index.php
post #5 of 9 (permalink) Old 09-08-2011, 10:51 AM
Reviews: 98
You could still use F-spacing. It's just cosmetic anyway--the pickup poles line up better under the strings.
AlaskaBat is offline
post #6 of 9 (permalink) Old 09-08-2011, 09:42 PM
Not always true. My RG270DX has Duncan '59s in it. They are not F Spaced and you can really see as you get toward the thinner strings that the pole pieces do not line up. The very bottom E string is on the edge of the bottom pole piece. When I pluck up I get correct volume, but when I pick downward I lose a lot of volume on that one string. I can only assume it's popping outside of the magnetic field far enough to lose a lot of the signal. This probably depends on the specific pickup more than anything else. Personally I'd go F-spaced when it's called for whenever possible just to be safe.
gideond is offline
post #7 of 9 (permalink) Old 09-09-2011, 03:05 AM
Originally Posted by enb141 View Post
Hi, I'm asking a few questions before buying the parts for my custom made guitar, one of the questions I have is which tremolo should I got, FLoyd Rose Pro or Floyd Rose Original? I'm asking this for the original one not the licensed one.
You only need to ask yourself: do I like a low-profile trem or do I not care. The only reason to get the PRO is if dislike the whale-tail design of the Original. Quality is equal. PRO is not hard to find - ProRockGear, GPDUSA, eBay
CrossingStar is offline
post #8 of 9 (permalink) Old 09-09-2011, 04:12 AM
Hey, you should measure the distance between the 1st and 6th string above the pickup area. If the distance is approx 48-49mm, use regular spacing. If the distance is approx 51-52mm, use F-spacing.
From what i know, floyd briges normally use F-spacing.
Hope this helps!
Bennelsonlim is offline
post #9 of 9 (permalink) Old 09-09-2011, 03:51 PM Thread Starter
Hope this helps!
Yeah I also knew that Floyd Rose Original uses F-Spacing but not sure what's better for Floyd Rose Pro and I'm also trying to decide which one should be better for my guitar project.
enb141 is offline
floyd rose original , floyd rose pro
WTB: Black Gotoh Floyd Rose or Black Original Floyd Rose supergirl20_06 Classified Ads: Guitars and Gear 1 06-11-2011 07:14 AM
WTB Original Floyd Rose or GOTOH floyd rose callen3615 Classified Ads: Guitars and Gear 3 01-22-2011 02:12 PM
FS: Original Floyd Rose & Floyd Rose 2 -zct- Classified Ads: Guitars and Gear 6 09-02-2005 03:07 PM
Original Floyd Rose or Floyd Rose Pro? Fatal-Tragedy Tech: Setup, Repairs and Mods 3 08-03-2004 09:56 PM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 12:06 AM
