Floyd Rose on Strat Body - Jemsite
post #1 of 14 (permalink) Old 11-06-2013, 09:12 PM Thread Starter
Hi guys, just installed a floyd rose on a strat body, trying to have a frankenstrat done, however, the strat body has no floyd cavity, like this one:
So the floyd lies flat on the strat body, the thing is, the string hight is to much, a really high action, I was wondering if there's a way to lower the strings a little bit?
Thanks!
Arturo
arturocivit is offline
post #2 of 14 (permalink) Old 11-06-2013, 09:22 PM
RGTFanatic's Avatar
Re: Floyd Rose on Strat Body
You could go deeper on the shelf route (and drill the anchor bores deeper) and add a shim to the neck. Of course this depends on how high your action is now...........
RGTFanatic is offline
post #3 of 14 (permalink) Old 11-06-2013, 09:31 PM
Reviews: 98
if it's a true "Frankie" replica, remember--there was no trem rout. Hence, the divebomb only we got with those early to mid 80s guitars.
But since you've already routed--follow Ryc's suggestions.
AlaskaBat is offline
post #4 of 14 (permalink) Old 11-06-2013, 09:44 PM Thread Starter
One thing, I didn't routed, I want a true "replica" the picture above is an example of what I'm trying to explain, there's no rout in the body of the guitar, but because of that the strings action are to high.
post #5 of 14 (permalink) Old 11-06-2013, 09:46 PM Thread Starter
Sorry for the ignorance, but, what is a shim?
post #6 of 14 (permalink) Old 11-06-2013, 10:05 PM Thread Starter
Here's a picture of my action
post #7 of 14 (permalink) Old 11-06-2013, 10:28 PM
Reviews: 120
This should help you regarding the shim.
http://www.premierguitar.com/article...a-bolt-on-neck
LonePhantom is offline
post #8 of 14 (permalink) Old 11-06-2013, 11:23 PM
RGTFanatic's Avatar
Drill the anchor holes a little deeper. then push the anchors to the bottom. That and a neck shim will fix this for you. A neck shim alone won't do it.
post #9 of 14 (permalink) Old 11-07-2013, 12:23 PM
+1 on shimming the neck
GuitarMechanic is offline
post #10 of 14 (permalink) Old 11-08-2013, 02:38 PM
Reviews: 98
Here's another link that describe neck shimming:
http://projectguitar.ibforums.com/pa...nd-purpose-r38
post #11 of 14 (permalink) Old 11-08-2013, 03:01 PM Thread Starter
Thank you!
post #12 of 14 (permalink) Old 11-13-2013, 03:25 PM Thread Starter
Update:
Finally! I just tried with a piece of an old credit card but didn't worked, so I tried with a guitar pick and now the string height is perfect, thanks so much to everybody for the help!
Arturo
post #13 of 14 (permalink) Old 11-13-2013, 03:41 PM
Reviews: 17
Pics man, show us a before and after and also, pic of the whole guitar please :d
Speedabob is offline
post #14 of 14 (permalink) Old 12-06-2013, 08:05 PM
jb4674's Avatar
Reviews: 18
I agree. I'm having a similar issue with my Yamaha RGZ 321P. I swapped the stock TRS-101 trem (Takeuchi) with an Original Edge. I had to sand the sides of the cavity a bit to make the trem fit the cavity but now I have 2 issues going on:
1. The string height is high
2. There's no space in front of the trem and, as a result, dive bombing is very limited.
Can anyone tell me if I could use a sanding bit for a dremel tool on my drill in order to add more space in front of the trem? I need about 1/8" of clearance so the trem can move properly?
Here are some pics:
Before (bone stock)
After (with Ibanez Edge)
Jimmy
jb4674 is offline
floyd rose on strat body
Need Fender Strat with Floyd Rose recommendation.. windycitycane All Other Guitars (including Prestige) 18 09-17-2013 02:25 PM
2008 Fender FSR EMG Floyd Rose Strat manticus Classified Ads: Guitars and Gear 3 06-24-2013 01:37 PM
WTB Strat Style Body for Wood Screw Floyd Rose CosmicDebris Classified Ads: Guitars and Gear 0 07-18-2012 12:04 AM
Redid my 93 US Floyd rose strat GaveUp All Other Guitars (including Prestige) 7 01-29-2012 02:05 PM
WTB: fender strat with floyd rose trem IanRG7421XL Classified Ads: Guitars and Gear 11 05-29-2007 03:41 AM
