Fret Buzz help - Jemsite
post #1 of 12 (permalink) Old 11-07-2011, 05:36 PM Thread Starter
Fret Buzz help
I just picked up 2000 S470 for $50 ....The controll cavity was smashed in. the frets were Toast, so I did a refret with some 57x110 jumbo wire from LMI. I did a level and crown three times already! Every string is fine except the low E. I cant get the action any lower than about 5/64th at the 14th fret. Even then it still buzz's. I've got no High or low frets with my fret rocker. I am certainly not an expert but I am not a novice either. I have done many refrets with out a problem. It buzz's heavily on every fret.
There are no loose frets, every one was pressed in and glued with CA....
Any ideas?
sli38 is offline
post #2 of 12 (permalink) Old 11-07-2011, 05:50 PM
Sho
Re: Fret Buzz help
Check the truss rod adjustment
My low e buzzed 1/1000th almost stopped it but mine has a high fret. Still could be an issue
Sho is offline
post #3 of 12 (permalink) Old 11-07-2011, 05:53 PM Thread Starter
Re: Fret Buzz help
Relief in the neck doesn't seem to help much.
sli38 is offline
post #4 of 12 (permalink) Old 11-07-2011, 06:13 PM
Re: Fret Buzz help
Is it fret buzz or is the saddle tail buzzing? Or if you string with the ball end at the tuner some ball ends can buzz like crazy.
I'm assuming you know it's fret buzz. Did you change the string? Past that, try lowering the action. You can find a point in a lively guitar that seems to oscillate with greater amplitude that higher action, you hear the buzz pinging off 1-2 frets far worse than you will with lower action where it's hitting 4-5 frets. Worth a shot anyway.
Rich is offline
post #5 of 12 (permalink) Old 11-07-2011, 07:39 PM
Re: Fret Buzz help
I'd look at the bridge for answers.
It may be something to do with the saddle.
sebastian is offline
post #6 of 12 (permalink) Old 11-07-2011, 08:42 PM Thread Starter
Re: Fret Buzz help
Well thanks for the help. I changed the strings with same result. From D'addario 9's to Ernie ball's. Both sets are 9-42. I just changed the low E 42 to a 43 from a set of GHS Fatties I had kicking around and it did the trick!! I have never had that happen, I thought I was going to pull my hair out. I had gone so far as to change the saddle out from an old trem I had sitting around. I still don't get whats really going on. Am I destined to use GHS Fatties from now on? What a PITA....
sli38 is offline
post #7 of 12 (permalink) Old 11-07-2011, 08:47 PM
Re: Fret Buzz help
D'Ad's and EB's are buzzy strings. Metalurgy has allot to do with buzz.
Rich is offline
post #8 of 12 (permalink) Old 11-07-2011, 09:00 PM Thread Starter
Re: Fret Buzz help
BTW...here is my set up. My own version of the SM neck jig. Works great!
sli38 is offline
post #9 of 12 (permalink) Old 11-08-2011, 02:49 AM
Re: Fret Buzz help
how good is your crown on the frets. That can make all the difference if the top is too wide. I dressed several different guitars and about half of them had that same problem because of the crown, so sometimes you can pull it off but it plays a huge roll in your issue. The only way to get it perfect is with a triangle jewelers file the old fashioned way.
JBOrocks is offline
post #10 of 12 (permalink) Old 01-22-2012, 01:23 PM
Re: Fret Buzz help
Hello,
may I ask what is the "crown"? Thanks=)
Wakizashis is offline
post #11 of 12 (permalink) Old 01-22-2012, 09:58 PM
Re: Fret Buzz help
its the arc on the fret if looking down the side. If the flat spot on top of the crown (the peak of the fret) is too wide it can cause buzz or more likely bad intonation.
JBOrocks is offline
post #12 of 12 (permalink) Old 01-23-2012, 01:12 PM
Re: Fret Buzz help
Ha, thought that. But thank you for assuring myself.=) My luthier has nice round file (actually it copies he arc of fret), he showed me last time i visited him with my guitar for fret refinish (that crown refinish). Thanks once more.
fret , ibanez , s470
Got a new guitar, but its got fret buzz on one string at one fret how to fix? ibanezcollector Tech: Setup, Repairs and Mods 6 11-25-2006 06:43 PM
Fret buzz on 13th fret AleTheNervo Tech: Setup, Repairs and Mods 1 04-19-2006 07:49 PM
fret buzz - above 12th fret nat1201 Tech: Setup, Repairs and Mods 6 04-11-2002 12:29 AM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 04:35 AM
Strange fret buzz - Only at 16th fret, G string carlos seo Tech: Setup, Repairs and Mods 3 02-06-2001 11:12 PM
