Fret buzz problems on HR Giger RG - Jemsite
post #1 of 8 (permalink) Old 01-19-2006, 03:06 AM Thread Starter
I just bought a new HR Giger RG from my local dealer. When I restrung it and set it up for 11-52's so I can play in C, I've noticed a lot of buzzing, especially on my bottom string. It also sounds like it has a dead spot on the 8th fret. It is possible it needs to have the frets leveled?
psycle_1 is offline
post #2 of 8 (permalink) Old 01-19-2006, 03:17 AM
Re: Fret buzz problems on HR Giger RG
Well considering you've just stepped up 2 gauges of strings, i would adjust the action first as the strings are much thicker. first off an 11-52 set for low C is way too light, its going to buzz as soon as you start picking it anything but softly. I find my 12-56 set too light.
ibanez.shredder is offline
post #3 of 8 (permalink) Old 01-19-2006, 03:23 AM Thread Starter
Correction: 11-54 set of strings. I've already done a setup on it - action was way too high from the factory, and after putting the new strings on, it made it much worse. I have a USRG30 set up the same way and didn't have any problems. I guess my real question is if it is possible for a factory fresh guitar to need a fret level job.
psycle_1 is offline
post #4 of 8 (permalink) Old 01-19-2006, 03:29 AM
Hmm okay. Look at the neck from down the headstock, can you see any raised frets (ie higher than the other frets)? also look at the neck from directly side on, any raised frets? and also check to make sure that the ends of the fret or the fret itself isnt coming out of the slot. It is possible that a factory guitar may need a fret level, but i hugely doubt it. Ive never had any such problems with my prestiges and RG5XXs.
EDIT: OPPS sorry i forgot that the HR giger models were MIK not the prestige line. Yeah on a Korean its possible that it might neeed one.
post #5 of 8 (permalink) Old 01-19-2006, 04:01 AM
It's entirely possible that a Korean production guitar could stand a fret-level. How low do you have the action set?
toshiro is offline
post #6 of 8 (permalink) Old 01-19-2006, 04:03 PM Thread Starter
Action is 2mm on low string @ 12th fret, 1.8mm on high string.
psycle_1 is offline
post #7 of 8 (permalink) Old 01-19-2006, 07:19 PM
Hmm thats the perfect action level so it does point towards a fret level problems dosnt it? what about truss rod position?
post #8 of 8 (permalink) Old 01-19-2006, 08:20 PM
Yet to see a genuinely acceptable setup on a Korean Ibanez, so I'd say 90% chance the frets need levelling and recrowning - it'll make the guitar feel sooooo much better anyway! - you'll need to get the intonation adjusted to suit C tuning regardless.
David McCarroll is offline
fret level , truss rod
Got a new guitar, but its got fret buzz on one string at one fret how to fix? ibanezcollector Tech: Setup, Repairs and Mods 6 11-25-2006 06:43 PM
fret buzz - above 12th fret nat1201 Tech: Setup, Repairs and Mods 6 04-11-2002 12:29 AM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 04:35 AM
problems with fret buzz - help me please serrana Tech: Setup, Repairs and Mods 5 01-15-2002 04:20 PM
Strange fret buzz - Only at 16th fret, G string carlos seo Tech: Setup, Repairs and Mods 3 02-06-2001 11:12 PM
