Fret falloff/fall away - Jemsite
post #1 of 6 (permalink) Old 07-04-2013, 09:49 AM Thread Starter
A while back there was a thread where there was a decent argument going on between Rich and this guy musikron who used to post here regarding fret falloff/fall away:
http://www.jemsite.com/forums/f21/if...ut-112774.html
Rich is obviously not a proponent of this while musikron is.
Well some time back I sent my Jem FP neck to musikron. It was suffering from scarf joint shrinkage and he said he could fix it. He actually did a fantastic job fixing the neck and now it plays great. I have to leave a little more relief in it than I normally would, but it's still a great neck.
Anyway, I was just checking the setup on this guitar the other day and I noticed that he had cut some falloff into frets 21-24. Basically, the neck is completely flat in that area and the frets are dead level, but then 21 is slightly lower than 20, 22 slightly lower than 21, etc.
Honestly, I really like the frets done this way. I've noticed that this guitar sustains better and plays cleaner above the 12th fret, particularly on bends and I'm now sure this is why. The strings aren't fretting out on the last couple frets, which they have a tendency to do because there's no bow in the neck in that range.
It definitely makes the setup a little more complicated, since you have to account for the falloff in order to set string action and neck relief properly, but count me as a fan of this.
PS: this is not an endorsement for musikron. He did fantastic work on my FP neck, so I later sent him two other necks to work on. He had those necks for months, made excuses about delays, then charged me for work he didn't do. I later paid Rich to do the work musikron claimed to do on a JC neck.
Worst of all, I had dropped the necks off personally while on a business trip, in a box that was good enough to protect the necks but not suitable for shipping. When he shipped the necks back, he didn't re-box them (which I insisted on). One of the two necks was damaged in shipping (thankfully only cosmetically) and when I contacted him about it, I was of course completely ignored. DO NOT DO ANY BUSINESS WITH THIS DIRTBAG.
Takin' a Ride is offline
post #2 of 6 (permalink) Old 07-04-2013, 12:47 PM
Re: Fret falloff/fall away
Thanks for the info on two fronts.
sebastian is offline
post #3 of 6 (permalink) Old 11-29-2013, 10:05 AM
RGTFanatic's Avatar
I totally missed this thread before, but.............
I'm also a fan of fall-off. Your right that it DOES make setup a bit more difficult but the bonuses it gives in playability, especially from #14-up, make it worth while. The biggest difference for me seems to be on bends. I don't get choke-out with bends on a low action setup the way I do with a perfectly level fret job.
The big down-side to having it done is that you HAVE to know and trust the person doing the work. This is a process that's done by hand with no safeguards against over cutting the frets. It can be screwed up very easily in which case the whole fret job has to be started over- possibly requiring new frets wherever the fall off was done.
RGTFanatic is offline
post #4 of 6 (permalink) Old 12-02-2013, 08:49 AM
I too have found that falloff helps in the upper frets. I used the method described by frettech.com.
andrewgosline is offline
post #5 of 6 (permalink) Old 12-02-2013, 01:34 PM
Can you be a bit more specific about where you found this on frettech, i have looked and cannot find anything about fret fall off.
Maxsys is offline
post #6 of 6 (permalink) Old 12-03-2013, 08:37 AM
frettech.com - Info and pictorials - level and crown tutorial.
Just says create angle with pieces of tape and sand away. I only did 2 pieces, though he recommends 4. I found that using 2 pieces of tape, one on the fret, and one covering the sandpaper gave me a bout .004 or fallaway from the 13th to 24th fret. I have done it to my two most recent level&crown jobs and found it works well.
Some fall photos Rotti Off-topic / Miscellaneous 25 10-28-2007 08:32 AM
No Vai This Fall With G3!!!!!!!!!!!! flarocks Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 142 06-16-2006 05:54 PM
No Vai This Fall With G3!!!!!!!!!!!! flarocks Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 04-27-2006 10:34 AM
Vai fall tour? Ekim Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 10 09-30-2004 04:20 PM
Shadows Fall matt_cater Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 6 08-17-2004 04:12 AM
