Fret Polish with Micro Mesh - Jemsite
post #1 of 7 (permalink) Old 09-06-2011, 07:23 PM Thread Starter
Hello Everyone,
I just purchased a used RG770DX. I thought I would post the fret polish process in a separate thread for an easy reference.
I know that there are many different ways to restore/polish frets but I been using micro mesh and have had great sucess and wanted to share with the community..
Don't think that polishing is just cosmetic. It also make the neck play much smoother now.. B4 it flet like someone put some maple syrup on the board....It feels awesome now..
TAPE UP Fretboard
Since my maple board has a top layer of clear I did not want to risk sanding it out the clear when polishing the frets. So I taped up the board with some good old painter's tape. I don't bother taping the board up on my rosewood or ebony boards. Stew Macs sells fret board protectors that would be really hany for this... Need to order a few of those...
BE SURE TO CLICK THE BAR AT THE TOP OF EACH PHOTO TO SEE THE FULL SIZE IMAGE.. IT REALLY MAKES A DIFFERENCE!!!!
Micro Mesh
4000, 6000, 8000, 12000... I dip the MM in soapy water to make them last longer.. You can use them dry also
4000 does most of the heavy lifting you can really see the difference just after the 4000.. (4th fret is UN-polished)
apadua is offline
post #2 of 7 (permalink) Old 09-06-2011, 07:29 PM Thread Starter
Re: Fret Polish with Micro Mesh
Before and After Pics
apadua is offline
post #3 of 7 (permalink) Old 09-06-2011, 07:33 PM Thread Starter
Cleaned board with warm soapy water....
apadua is offline
post #4 of 7 (permalink) Old 09-07-2011, 06:08 AM
Reviews: 17
Excellent tutorial mate
Speedabob is offline
post #5 of 7 (permalink) Old 09-07-2011, 09:37 AM
You should always remove the neck from the body if possible to do fretwork. Last thing you need is grit and junk getting onto the pickups or into the electronics.
Also, the white balance on your camera is really messed up. All the pics have a very yellow tint, makes it hard to see what you're doing.
Takin' a Ride is offline
post #6 of 7 (permalink) Old 09-07-2011, 04:29 PM Thread Starter
Originally Posted by Takin' a Ride View Post
You should always remove the neck from the body if possible to do fretwork. Last thing you need is grit and junk getting onto the pickups or into the electronics..
Good tip.. I can see myself removing the neck if was using steel wool.. But with MM I do not think it is necessary..
Hmmm.. I just have it set to FULL AUTO for most of the shots.. The color is actaully very close to how it looks like in person..
apadua is offline
post #7 of 7 (permalink) Old 09-07-2011, 05:41 PM
looks great bro ...
pink13 is offline
770dxvm , fret polish , micro mesh
Micro Pog Settings Tannen Gear, Equipment, Recording & Off Topic 1 09-19-2010 07:28 AM
WTB UK: Micro POG Devo Classified Ads: Guitars and Gear 1 11-20-2008 05:10 AM
Boss Micro BR Moibanez Gear, Equipment, Recording & Off Topic 1 10-21-2007 11:26 AM
Boss Micro BR nickcoumbe Gear, Equipment, Recording & Off Topic 5 05-24-2007 07:00 AM
Micro notes metalguitarist7778 Gear, Equipment, Recording & Off Topic 8 06-07-2006 08:18 PM
