the G string! - Jemsite
post #1 of 4 (permalink) Old 11-10-2003, 11:28 AM Thread Starter
the G string!
why is it that the G always seems to get knocked out of tune easier then any other?
rg2120 is offline
post #2 of 4 (permalink) Old 11-11-2003, 01:32 AM
ScottB's Avatar
It is the largest of the plain strings, so therefore the gravitational pull of the sun, combined with earth's gravity pulling in the other direction seem to wreak havoc upon the G string and cause it to go out of tune sooner than the others.
ScottB is offline
post #3 of 4 (permalink) Old 11-11-2003, 01:39 AM
as my manager states with any problem in the store (or life in that matter) "it's gotta be sun spots"
RSVampire is offline
post #4 of 4 (permalink) Old 11-11-2003, 01:27 PM
I didn't want to get into this one but since its getting nutty I thought I'd give you something to sink your teeth into. First, yes the G is the largest plain, which is important because it also makes it the least forgiving to tension changes. That saddle is usually the farthest back (besides the low E) to compensate for the pull sharp when fretting. Slight changes in tune are most noticeable on that string. Evidence for that would be to give each tuner exactly one half turn sharp, and see which string has the greatest pitch travel.
Second, and perhaps more important, is that the G seems to go out of tune more often because of it's place in the tuning scheme. Between the G and B is only a 4 step interval while the rest are 5. I don't know quite how to say it, but there's a weird relationship going on right there. I've found that if the G isn't tuned properly, it becomes the main offender in the chords that are out of tune. The G and B relationship is usually the cause, and I find that they usually sound best together when the E through G set is pushed a little sharp progressively, then the B is a little flat against the G. The high E is in tune with the B. This sounds the best to me, and gets all my chords in tune.
The compensated nut idea (having the contact points at the nut loosely resemble the stagger at the saddles) is brilliant, too, because most of the time, the G sounds sharp when fretting it at the first couple frets because you are pulling it sharp. On a jumbo fret guitar (this IS the jemsite ) you can squeeze the G sharp very easily. I think the compensated nut does 9/10ths of what the Feiten tuning system does.
So to sum it up, part of it is because it does "knock" more out of tune, all things being equal, and part of it is because the guitar is a crazy beast. I'm not ready to concede to sun and moon or what kind of underpants you have on or whatever
frankfalbo is offline
feiten tuning system , fret guitar , tuning system
Ibanez Iron Label RG 6 String vs. Jackson DK2M Pro Series Dinky 6 String ? Riley Macdonald All Other Guitars (including Prestige) 6 06-16-2013 12:35 AM
Did you guys see the Ibanez 9 string prototype from namm? (8 string j custom inside) WYLD STALLYNS All Other Guitars (including Prestige) 12 02-02-2013 11:31 AM
WTB: Left hand tuners, top-mount nutlock and string retainer for Ibanez 7 string (UK) leec Classified Ads: Guitars and Gear 4 09-05-2012 09:33 AM
Bass pickups in 7 string and 7 string single coil demo juiceofvenus Pickups & wiring 4 08-29-2003 02:54 PM
7-String Tune-O-Matic? 7-String String Saver Saddles? Drache713 All Other Guitars (including Prestige) 1 12-03-2002 11:27 PM
