Got balls ... or not (Edge Pro) - Jemsite
post #1 of 8 (permalink) Old 03-11-2004, 12:43 PM Thread Starter
Hi for all of you that have the new Edg Pro equipped guitars, do you use your strings with the ball still attched or do you still cut it off ?
Does it make any noticeable difference in tuning stability, sound or whatever ?
Cheers
chlamy is offline
post #2 of 8 (permalink) Old 03-11-2004, 03:16 PM
the first couple of times i retrung it i left the ball ends on. but now i string with the ball ends up at the headstock, just because it looks cool.
Never noticed any difference in tone or stability, and i only need to cut the string once this way anyway.
matt_cater is offline
post #3 of 8 (permalink) Old 03-12-2004, 12:48 PM
Try it both ways and you'll soon find out how much of a pain loading the balls are
Rich is offline
post #4 of 8 (permalink) Old 03-12-2004, 02:16 PM
I don't own one, but I've strung a few and my question is this . . .
What's the point?
If you don't cut the balls off you have to open the saddle enough to push it through, in my opinion it actually seems to take LONGER since you have to sit there and and turn the screw quite a bit farther to fit the ball through than just opening it enough for the string.
I like that the "lock-block" is part of the saddle, no more dropping the little things, but as to leaving the balls on, there is no real point.
I have them at the headstock anyway . . . :-)
Mic
MicJustMic is offline
post #5 of 8 (permalink) Old 03-12-2004, 02:23 PM
You've read my review haven't you
Rich is offline
post #6 of 8 (permalink) Old 03-12-2004, 02:34 PM
I think so . . .
But regardless, I guess I'm in agreement even if I hadn't.
I strung one Edge Pro II and three Edge Pros, while the II is a major improvement over the TRS, and the Edge Pro feels, to me anyway, very much like the original Edge(s) in action, the fact Ibanez is touting the idea of easier string changes by leaving the balls on is just, well . . . I don't know.
Dumb?
Mic
post #7 of 8 (permalink) Old 03-12-2004, 02:55 PM
Stringing that way - dumb.
Touting it as easier - misguided.
Rich is offline
post #8 of 8 (permalink) Old 03-12-2004, 03:04 PM
After thinking about it, the only way I could see this being easier would be if they had designed it so that you could pull the strings through the back, like a a Strat bridge, have the ball seated in the block (like a Strat) THEN you clamp the string at the saddle as normally.
No faster than stringing with the balls at the headstock, BUT, in a pinch this could make for a faster single string replacement in an emergency situation since you wouldn't need to find your string cutter at all . . .
But then there's still the Top-Loc, and stretching, and floating and . . .
Oh forget it, it works as it is, I'm going to watch Kirsten Dunst and Eliza Dushku jump around in cheerleader outfits and pretend I'm 10 years younger . . . :-D
Mic
edge pros , equipped guitar , strat bridge
I finally got 2 Balls - Axis and JP6 evolvedmb All Other Guitars (including Prestige) 12 05-09-2010 08:08 PM
My Balls.. (Offensive Content) shogun Gear, Equipment, Recording & Off Topic 31 05-13-2008 10:31 PM
im breakin my balls here and still no1 cares! --matt. Off-topic / Miscellaneous 19 05-23-2007 05:57 PM
Balls or no balls? Edge Pro... Dee Polls 26 07-22-2006 12:46 AM
D'Addarios vs. Ernie Balls? TheJazzTerminator Tech: Setup, Repairs and Mods 19 06-19-2006 02:37 PM
