Gotoh 1996t trem posts - Jemsite
 1Likes
  • 1 Post By Jono82
post #1 of 6 (permalink) Old 12-04-2016, 05:17 PM Thread Starter
Does anyone know if the Gotoh posts will fit into the mounting points that an original Edge uses?
I want to replace Edge with Gotoh and was wondering if I was going to get new posts, if I could use the Gotoh ones or if it'd be better to buy new Edge ones. I don't want to have to pull out the studs and reroute the body. I just want to replace the posts.
Jono82 is offline
post #2 of 6 (permalink) Old 12-04-2016, 10:08 PM
Reviews: 120
Re: Gotoh 1996t trem posts
From memory they are the same thing. I could be wrong though.
LonePhantom is offline
post #3 of 6 (permalink) Old 12-05-2016, 07:15 AM
If memory serves me right, one is 25 mm long and the other is 31, I don't remember which is which though. Check gotoh website I believe they have detailed drawings that call out the post length. You can compare them to the edge posts you have. Also depending how tight the bridge cavity is, you may have to sand/rout the treble side of the cavity to make the gotoh fit.
kissTheApex is offline
post #4 of 6 (permalink) Old 12-05-2016, 02:30 PM
I put gotohs on a few Jems with no problems, I just used the posts that came with the GT1996. The Ibanez posts didn't work, but the holes were fine.
The edges of the Gotoh will not totally line up. There will be a slight gap on the bass side, and the treble side is a tight fit. Doesn't bug me. Best bridge on the market, IMO.
Ethn Hayabusa is offline
post #5 of 6 (permalink) Old 12-06-2016, 01:40 PM Thread Starter
That's good information.. thanks.
Ethn Hayabusa likes this.
Jono82 is offline
post #6 of 6 (permalink) Old 04-29-2020, 07:44 PM
How did you remove the edge bushings or did you leave theM in?
jayroc123 is offline
floyd , gotoh , posts
Will GOTOH GE-1996T LICENSED FLOYD ROSE fit Edge Pro III canevrosen Tech: Setup, Repairs and Mods 2 09-02-2015 09:27 AM
Edge pro trem or Gotoh trem wanted jsdisciple Classified Ads: Ibanez JEM/UV Guitars 0 06-08-2011 08:59 AM
FS: Ibanez Edge trem in black + arm, posts, locking nut, string tree and Gotoh tuners lewis.mann Classified Ads: Guitars and Gear 0 08-12-2008 12:20 PM
Best Trem Posts LonePhantom Tech: Setup, Repairs and Mods 12 05-02-2008 10:52 AM
where can I get the trem posts for the Edge trem? rx Ibanez JEM, UV, JS & Other Signature Models 6 03-17-2005 08:24 PM
