To Grind the Bottom of a TopLok - Jemsite
post #1 of 10 (permalink) Old 03-08-2017, 02:46 PM Thread Starter
Question To Grind the Bottom of a TopLok
What would be the best recommendation for someone at home to grind a floyd nut? This guy here uses an old fret leveling file and a vice for his saddles and nut:
https://fretmechanic.wordpress.com/t...yd-rose-setup/
Was wondering if someone had any other recommendations.
jemboyee is offline
post #2 of 10 (permalink) Old 03-08-2017, 02:59 PM
Re: To Grind the Bottom of a TopLok
When you say [and he says] grind, that entails using, a grinder. Not a file. If he had to take .5mm off that nut he'd be at it for hours.
Grinder.
Rich is offline
post #3 of 10 (permalink) Old 03-08-2017, 03:40 PM Thread Starter
Recommend anything from Home Depot for the job?
jemboyee is offline
post #4 of 10 (permalink) Old 03-08-2017, 03:51 PM
They sell grinders
Rich is offline
post #5 of 10 (permalink) Old 03-08-2017, 04:02 PM
Did you make the neck it's going on?
If it's a real Ibanez neck, you may not need to grind it down.
sebastian is offline
post #6 of 10 (permalink) Old 03-08-2017, 05:25 PM Thread Starter
It seems easier just to take a sliver off of the nut shelf.
jemboyee is offline
post #7 of 10 (permalink) Old 03-09-2017, 06:24 AM
It may not solve your problem.
It might be neck angle.
post #8 of 10 (permalink) Old 03-09-2017, 10:12 AM Thread Starter
Nothing to do with neck angle. The break off of the nut is too high.
jemboyee is offline
post #9 of 10 (permalink) Old 03-09-2017, 11:43 AM
Smile Re: To Grind the Bottom of a TopLok
Just file the shelf down.
Wood is easy to file or sand.
post #10 of 10 (permalink) Old 03-18-2017, 12:50 AM
A cheap 6" - 8" dual grit knife sharpening stone soaked in some wd40 may do the job for ya. Chuck the stone in a vise, run the nut back and forth rotating the nut 90 degrees every so often while spraying additional wd to keep it lubricated.
Dragula is offline
I want to thank y'all, from the bottom of my Jem10. Oracle13 Ibanez JEM, UV, JS & Other Signature Models 13 03-09-2008 06:10 PM
Re-designed TopLok-III? (Rich?) nuno Ibanez JEM, UV, JS & Other Signature Models 7 02-19-2007 06:48 PM
Bump and Grind tab? moro Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 05-23-2006 11:43 AM
My bass rig needs some TUBE GRIND to it...help tomizm Gear, Equipment, Recording & Off Topic 0 10-03-2002 07:20 PM
Bump and Grind - How damaged are you Beavis Tech: Setup, Repairs and Mods 4 11-14-2001 12:30 PM
