grounding problems? - Jemsite
post #1 of 2 (permalink) Old 05-27-2002, 08:14 AM Thread Starter
grounding problems?
My RG570EX produces "hum" (or non-grounded noise) at high gain settings when I'm not touching the strings. When I touch the strings at the neck, the noise dissapears and then when I have my both hands on the strings, the noise starts again. My right hand rests in the strings near bridge pu.
I have notices this problem in every guitar I've played (that's not many). Is it so that when a guitar comes out of factory, it's grounding needs to be done again? My RG is brand new..
All the guitar's I've played have had factory setups
Lauri M is offline
post #2 of 2 (permalink) Old 05-27-2002, 10:19 AM
Sounds like just regular hum you get from guitars at hi gain settings..
as far as grounding problems, when you put your hand on the strings you are closing the circut and grounding the guitar with your body, but when you put both hands on them you open the circut again.. some guitars are tricky to do a good grounding job on.. Most guitars have a ground wire running from the electronics to the bridge, relying on your body as a ground.
bigfootguitars is offline
Grounding? m t soule Tech: Setup, Repairs and Mods 1 04-07-2014 01:22 AM
Ibanez RG350EX Grounding problems eVILj All Other Guitars (including Prestige) 0 05-06-2011 03:34 AM
When is grounding necessary? bhuether Pickups & wiring 6 02-21-2009 02:40 AM
grounding a les paul ? j.arledge Pickups & wiring 0 11-03-2005 07:40 PM
Grounding Wire superhairycamel Pickups & wiring 2 09-22-2005 12:05 PM
