guitar going out of tune - Jemsite
post #1 of 4 (permalink) Old 01-11-2004, 07:13 PM Thread Starter
an annoying thing keeps happening to my guitar, it sometimes just goes out of tune at random, i dont have the nut locked and i have blocked my lo-pro, any advice on what i can do, it usually only happens on the thin strings.
woodros is offline
post #2 of 4 (permalink) Old 01-11-2004, 07:24 PM
I would first suggest using the locking nuts again. The tuning keys tend to slip a little if you havent noticed theya re just gears and its really kind of impossible for them not to slip to some extent. You could switch over to locking tuners though maybe sperzels. If you have to not use the nut you may want to apply some lube of some kind to the nut of your guitar. Also make sure you stretch your strings properly. Otherwise basically all guitars will go out of tune when the neck wood expands and contracts due to climatical changes. Try to leave it in a room where the tempature stays pretty much the same, out of sunlight
sniperfrommars1 is offline
post #3 of 4 (permalink) Old 01-13-2004, 01:34 AM
It's most likely just friction at the nut when you bend a string, or even just from the strings moving a bit when picking.
The locking nut on these guitars is NOT made to NOT be locked. It has a fairly large area where the string comes in contact, by design, to allow for a good grip on the strings when the blocks are locked.
Just lock the nut and use the fine tuners just like you would if you were using the trem un-blocked.
This should solve your problem.
If you just can't deal with locking the nut, or if you're using alternate tunings often and locking the nut is impractical, you may have to invest in installing a regular, non-locking nut on your guitar. This will look strange, since there is a large rout at the nut for the lock, and it may not even stay in place because there is no wood 'behind' the nut, but barring that, I see no other real options.
I doubt it's the tuners, as long as you're tuning UP when you do tune. The tuners on Ibanez guitars (even a lot of the 'cheap' ones) are all either good, very good or top quality and should give no problems.
I'm going to stick with friction at the nut/string tree. Simple as that. :-)
Mic
MicJustMic is offline
post #4 of 4 (permalink) Old 01-13-2004, 11:51 AM Thread Starter
thankyou for your advice. it is a bit stupid buying a lo-pro then not using it, but i got so used to not using the trem that when it finally came, i didnt want to use it, its good in a way because i have focused a lot more on my playing and technique. I think the best advice for myself, is to get a new guitar, i'd much rather have something with a wilkinson trem so i could still use it no and again. Can anyone tell me what guitars have those new wilkinson trems on them i'd like to look into it. thanx
woodros is offline
alternate tuning , alternate tunings , ibanez guitars , locking nut , locking nuts , locking tuners , string tree , wilkinson trem
guitar not staying in tune topher5150 All Other Guitars (including Prestige) 13 02-20-2013 05:22 PM
My guitar goes out of tune! (Edge) vicente_romma Tech: Setup, Repairs and Mods 6 12-08-2010 05:18 PM
guitar goes out of tune dartvader Tech: Setup, Repairs and Mods 0 05-10-2009 09:52 PM
Help Me tune my guitar Arteus Tech: Setup, Repairs and Mods 20 01-10-2007 01:50 AM
The auto-tune guitar fettouhi Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 9 12-31-2006 08:12 PM
