guitar neck question.. - Jemsite
post #1 of 5 (permalink) Old 07-24-2004, 01:30 AM Thread Starter
my guitar's neck is a 24 fretter, but it is a short scale neck, i'm not sure what's the scale, didn't measure it, but for sure it's much shorter than standard ibanez's neck scale. is it possible for me to install a 25.5 scale neck on that guitar? do i have to make extra routing on it or could i just bolt it in?
thanks for the help!
tonluvara is offline
post #2 of 5 (permalink) Old 07-24-2004, 07:19 AM
You could be lucky, but most probably it won't fit.
What you will have to do is difficult to say without knowing the scales, measurements. But, the Ibanez neck is made to a 25.5" scale. That means that there are 25.5" from the bridge to the nut, the "ringing string distance". Depending on your old neck, you will have to make the distance shorter or longer to make the Ibanez fit.
It's not the best thing to do, as it could end up totally wrong and is alot of work. I wouldn't do it. I'd rather try getting hold of a used Ibanez in working order. But you might have your reasons...
The Euphor is offline
post #3 of 5 (permalink) Old 07-24-2004, 12:23 PM Thread Starter
i just checked, my scale is 24.5? or somewhere around that.. it's definitely shorter than 25.5.. is it possible to extend a bit?
ahhah yeah, i just love this guitar soo much, but infortunately some parts are getting old, like the neck, that's why i have done some modifications since i bought it (blame it, it's a cheap korean made). since i can't stop playing this baby (although i already have a dbk) i've been trying to stop it from degrading by installing better parts..
the neck part isn't that urgent but will get its turn soon.. so yeah, i'm thinking of getting a longer scale one
post #4 of 5 (permalink) Old 07-25-2004, 01:48 AM
ScottB's Avatar
If the neck wood and fingerboard are in ok shape, maybe you should consider replacing the frets, or having the existing ones leveled and dressed if there's enough of them left to work with. You'd be surprised how much of a difference this would make on a "beat to hell" neck.
ScottB is offline
post #5 of 5 (permalink) Old 07-25-2004, 02:39 AM
Well, the 12th fret needs to be exactly half way between the bridge and the nut when the neck is installed, likewise, the 24th needs to be exactly 1/4th the scale length from the bridge. If you try to just bolt a longer scale neck onto the guitar, wouldn't the 24th fret be in the same location as it was for the shorter neck, meaning it would then be too close to the bridge? And all the other frets would be in the wrong place too, wouldn't they?
Unless you very precisely redid the neck pocket to make the new neck line up in the right place, and since you'd need to make the longer neck move away from the bridge compared to where the shorter neck was, there'd be a gap that you'd have to fill in. Doesn't seem to me like it would be easy or advisable.
Ferrous Lepidoptera is offline
ibanez neck , neck scale
Guitar Neck Scale length question 2DECADESSOFAR Gear, Equipment, Recording & Off Topic 14 08-10-2012 06:27 PM
To those who have built an electic guitar (not assembled one) - Double-neck question. Trfsrfr Tech: Setup, Repairs and Mods 4 11-23-2009 02:23 PM
Nooby Question: Cleaning the neck (not fretboard, neck!) mango_icecream Tech: Setup, Repairs and Mods 8 05-12-2008 09:03 PM
another neck question ---> sticky neck spacenuke Tech: Setup, Repairs and Mods 9 11-12-2002 10:45 AM
BSB Question - neck finish question j i m Ibanez JEM, UV, JS & Other Signature Models 7 02-23-2001 05:29 PM
