Guitar String Bending Problem - Jemsite
post #1 of 10 (permalink) Old 09-20-2011, 04:42 PM Thread Starter
basically whenever I bend the High E (1 and a half step) and or B string (whole step) it keeps going under the above string
ex. bending high e , finger goes under the b string
I have to put my hand into an awkward shape so that it doesn't go under the string
I'm using Ernie Ball Light top / Heavy Bottom strings
Action is set so that the bass strings don't buzz anywhere, Treble strings set to the height so that bending the high e on the 17th fret (1 and half step) doesn't choke(no buzz).
any tips on how to stop that ? or is it a guitar setup problem if so how can I fix it?
Ibzplayer is offline
post #2 of 10 (permalink) Old 09-20-2011, 09:01 PM
Reviews: 15
Re: Guitar String Bending Problem
IT will take a little practice, but you have to learn to use fret the note using the meat of your finger, and not the tip. That way, you use the tip to push the other string away and deaden it without fretting it all at the same time.
lespauled is offline
post #3 of 10 (permalink) Old 09-20-2011, 10:56 PM
Action is a players preference. But I think this is a good place to look.
http://www.ibanezrules.com/tech/setup/action.htm
sssteve72 is offline
post #4 of 10 (permalink) Old 09-20-2011, 11:09 PM
Reviews: 98
It would really help to know what guitar you're talking about, and whether or not it has a trem on it. Sounds like you may have a bridge radius issue. Look down the neck from the bridge to the nut. Do the strings curve to the same radius as the neck? Does the B string look higher than the others? That should be the first thing to check.
AlaskaBat is offline
post #5 of 10 (permalink) Old 09-22-2011, 12:45 PM Thread Starter
my guitar is and ibanez rg350ex with an Original floyd rose fitted in
post #6 of 10 (permalink) Old 09-22-2011, 01:28 PM
Reviews: 57
AlaskaBat is likely correct.
If the Floyd has not been set up correctly the radius is off for the neck. From the factory they have a shim to make it a 10" radius which pretty different from the close to 16" radius on that Ibanez. Removing the shim still only puts you at 12" ... you want to get saddle shims and install them under your saddles. Any decent tech could do it for you, it's not complicated if you want to do it yourself either.
Some info here:
http://www.rackcreations.com/forum/viewtopic.php?p=130
Shims are cheap here:
http://www.axcessories.com/products.asp?cat=25
blackspy is offline
post #7 of 10 (permalink) Old 11-08-2011, 02:52 AM
Sounds like a sit-down with an experienced player or an instructor will go miles here.
Sometimes another set of eyes and some experience are all that is needed. Doesn't sound like there is a setup issue.
jasondmckay is offline
post #8 of 10 (permalink) Old 11-08-2011, 05:22 AM
If the action is too high on the strings, you can slip under too.
sebastian is offline
post #9 of 10 (permalink) Old 11-08-2011, 12:18 PM
I agree with that, however if you've been playing for a while you'll just come to realize and get comfortable with certain things that happen. If he is fretting the notes with the tip of his finger versus the pad of it weird things can happen. I was just suggesting that someone else check out what he's doing. Just another set of experienced eyes can eliminate debate.
post #10 of 10 (permalink) Old 11-08-2011, 12:37 PM
Smile Re: Guitar String Bending Problem
Good Idea!
guitar bending action
String bending and floating trems olydj2000 Gear, Equipment, Recording & Off Topic 13 02-27-2011 06:47 AM
Sting changes tone when bending another string. Ibanezboy1 Ibanez JEM, UV, JS & Other Signature Models 3 02-15-2009 11:12 AM
String bending (low action) blackpuppets Tech: Setup, Repairs and Mods 12 10-27-2005 02:56 PM
High E string goes flat after bending eg Tech: Setup, Repairs and Mods 6 11-25-2004 05:35 PM
High E is too tight. - bending this string is a bugger Vai the god of Sound All Other Guitars (including Prestige) 8 01-14-2002 07:15 AM
