Half step down tunning, does it need truss rod adjustment? - Jemsite
post #1 of 8 (permalink) Old 06-30-2011, 09:52 AM Thread Starter
Well, that. I'm tunning down my RG a half step down. Common sense indicates that the less string tension would need less truss rod tension to compensate, so I loosened it a really REALLY tiny bit.
Am I right?
And also (I dont want to create another thread), during what seasons do you make truss rod adjustments?
paison90 is offline
post #2 of 8 (permalink) Old 06-30-2011, 10:14 AM
Reviews: 57
Re: Half step down tunning, does it need truss rod adjustment?
I wouldn't really be adjusting the truss rod without evidence that I needed to. You may have needed to adjust it for the tuning change, but you may not have. Really the only way to know is to measure and evaluate, unless its very obvious.
You may never need to adjust it seasonally, it depends on the neck and the climate.
blackspy is offline
post #3 of 8 (permalink) Old 06-30-2011, 11:55 AM
Try to get a measurement of neck relief with a set of feeler gages, or sheets of paper. If the neck relief gets too small, you need to losen the truss rod. I can't think of a good reference, but I believe it's best to adjust the truss rod without string tension.
For me, seasonal truss rod adjustments are 1/8" of a turn at most, and usually when the humidity goes low in the winter, then when the humidity comes back in spring.
andrewgosline is offline
post #4 of 8 (permalink) Old 06-30-2011, 06:10 PM
Ayrton's Avatar
I have never had to adjust the rod for a half step of tuning.
Ayrton is offline
post #5 of 8 (permalink) Old 06-30-2011, 06:55 PM
You should check your neck relief periodically regardless of what tuning you have on the guitar. Changes in temperature or humidity could necessitate an adjustment. If I haven't played a guitar in a while, I always check the setup.
Takin' a Ride is offline
post #6 of 8 (permalink) Old 07-01-2011, 08:11 PM Thread Starter
Well, talking about that, how'd you all set it up for a standard low action?
paison90 is offline
post #7 of 8 (permalink) Old 07-02-2011, 09:12 AM
I like about 0.3mm of relief measured at the 9th fret (measurement done with a capo on the first fret and hand-fretting the 24th fret). I like about the same clearance at the first fret if possible. Then I set the string height at the 24th fret so that the 2mm mark on my ruler is right in the middle of the 6th string and the 1st string is at 1.5mm.
post #8 of 8 (permalink) Old 07-02-2011, 09:47 AM Thread Starter
Cool. Mine is about 1mm at the 9th fret, and I can get it at 1.5mm on the trebble side but it buzzes at 2.4mm in the bass side. I'm guessing bad fret work?
paison90 is offline
half , rod , step , truss
Joe Playing one half step detuned SP2333 Ibanez JEM, UV, JS & Other Signature Models 14 02-21-2011 12:50 AM
9-42 strings tuned down half a step MrJacko03 All Other Guitars (including Prestige) 9 02-03-2007 01:45 AM
440 Hz tuning and half step down... Shaker3 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 05-08-2005 06:06 PM
Tuning down a half step... SuperDave All Other Guitars (including Prestige) 9 09-09-2003 01:22 AM
Help!! - ...can't tune down half-step Fabe Tech: Setup, Repairs and Mods 3 03-28-2002 05:26 AM
