Hard Case Latches broken from case (PICS) - Jemsite
post #1 of 10 (permalink) Old 07-09-2013, 04:51 PM Thread Starter
Hey guys, any ideas on how to fix a hard case whose all 3 latches broke off their places? I'm looking for a pretty DIY cheap, home made way to fix it I'm running out of ideas (ok ok I dont have any ideas!!!)
I have to travel by plane in 2 weeks and I'm taking it with me and as you can imagine this hard case does not close...
Please take a look at the pics
https://www.dropbox.com/s/60zgtjxonv6yy3y/latches.JPG
https://www.dropbox.com/s/ffylo5ogq6xiryb/lthcer2.JPG
All three latches are exactly the same, some idiot jumped on them or something, I dunno, I bought this guitar as is and though the guitar is beautiful, the case has its things...
Thanks in advance.
ErickMoral is offline
post #2 of 10 (permalink) Old 07-09-2013, 05:07 PM
Re: Hard Case Latches broken from case (PICS)
I don't think it would hold up, but you could glue the plastic parts together using acetone, then use some good straps to keep the case closed. I would buy a new case, if possible. I don't think I would consider that case to be great for protecting an instrument.
The Euphor is offline
post #3 of 10 (permalink) Old 07-09-2013, 05:11 PM Thread Starter
I know what you mean sir, but considering my actual financial situation I cannot afford to buy a new case, though your idea seems pretty much what I had in mind...
post #4 of 10 (permalink) Old 07-09-2013, 05:12 PM
Fixing 3 you're better off buying a case.
If it was just one you pull the case liner, use a metal plate with holes drilled at the rivet spacing. Drill out the rivets and use screws and nuts to bolt it together [leave the plastic in place to position the latch.
Rich is offline
post #5 of 10 (permalink) Old 07-09-2013, 05:23 PM
That should work with all three, shouldn't it? Bigger metal plates, more bolts.
post #6 of 10 (permalink) Old 07-09-2013, 05:25 PM
It'll work, but we're talking about a case better left for trash. If all the latches are broken I'd bet most of the feet are also. And it's not like you can just whip up the metal plates. I had a machine shop make me a stack.
Rich is offline
post #7 of 10 (permalink) Old 07-09-2013, 05:29 PM Thread Starter
That makes perfect sense, though I guess you are right, this case is just not something that I would like to keep, I just need it to get through the plane so I might stick with this solution temporarily, thanks Rick.
post #8 of 10 (permalink) Old 07-09-2013, 05:30 PM
For temp, duct tape.
Rich is offline
post #9 of 10 (permalink) Old 07-09-2013, 11:26 PM
Those are the worst latches. I can see it's SKB but Ibanez used the same for a while. I remember as a kid I bought a 100 Ibanez case for my 375 RFR RG550 and the middle latch broke I was so gutted! It wasn't even from rough wear n tear! Just rubbish. Anyway, either find a cheap deal on Craigslist, or as Rich says try Gaffa tape. Otherwise a good wrapping with clingfilm/plastic wrap would work.
GoodVaibes is offline
post #10 of 10 (permalink) Old 07-10-2013, 06:48 AM
I had this same problem and fixed it.
I got a piece of plastic that was about the same thickness as the case.
I made a long rectangle that fit inside the case where the hole is.
I drilled out the two round rivetish looking thinks that are on the butterfly latch that broke off.
This left me with me with two holes that I could bolt through.
I went to the hardware store and got two domed head allen bolts and locknuts just long enough to the latch and the piece of plastic I cut for inside the case.
I put the plastic on the inside of the case between the outer shell and the lining of the case.
You have to peal a short section away, it’s glued in.
Then I put the latch in place where it should be and drilled through the two holes on the butterfly latch.
Then I popped the two bolts through and put the nuts on the inside behind the plastic.
This sand wedged the whole thing together.
Now it works great!
sebastian is offline
hardcase
About to bend my case's latches, need advice. Blacksabba Tech: Setup, Repairs and Mods 12 03-27-2011 09:37 AM
FS : Parker P-38 inc Hard Case (UK) Ibanez-JEM7VWH Classified Ads: Guitars and Gear 0 12-16-2009 05:54 AM
Hard-Case. Ibanez EDA1000C Bass Case - NEW $40 Bowie Classified Ads: Guitars and Gear 0 10-12-2008 01:08 AM
J Craft hard case. PeteO Ibanez JEM, UV, JS & Other Signature Models 8 03-04-2008 12:25 AM
Want to Buy - Tounge latch for UV1000 HARD SHELL CASE, SAME CASE THE JEM SHIPS IN cradleofphil Classified Ads: Guitars and Gear 9 01-28-2007 01:29 PM
