Hard Shell Case Latch Repair - Jemsite
post #1 of 16 (permalink) Old 01-28-2015, 06:02 PM Thread Starter
Does anyone have any experience fixing latches on a hard shell case? I have a few cases with one (or in some cases two) broken latches. I have a couple generic cases for carrying guitars around, but wanted to fix up the original cases i have if it's doable and not cost prohibitive.
pwsusi is offline
post #2 of 16 (permalink) Old 01-28-2015, 11:22 PM
Re: Hard Shell Case Latch Repair
Yup, had some steel plates made years ago with the holes aligned to the latch. You drill out the rivets and use short screws with nuts on the inside. Pull the foam liner out, put the plate on the inside, latch and ABS piece, screw together, hot glue the liner back in [when using hot glue, make big blobs on the ABS and let cool considerably before you put the liner back in. The heat will melt the foam.]
Rich is offline
post #3 of 16 (permalink) Old 01-29-2015, 03:39 AM
Nice one
Zoot is offline
post #4 of 16 (permalink) Old 01-29-2015, 07:09 AM Thread Starter
thanks. As you can see from the pictures though i'm missing the latch itself. Any idea where i can find a good replacement? Also, any tips on where i can find plates like the one you're describing?
pwsusi is offline
post #5 of 16 (permalink) Old 01-29-2015, 01:46 PM
If you're missing the latch I got nothing for you. Buy another case.
Rich is offline
post #6 of 16 (permalink) Old 01-31-2015, 10:58 AM Thread Starter
Well thanks anyway. I did come across these...
http://www.reliablehardware.com/smalltwistlatches.aspx
I may take some measurements and see if i can make something like this work. I was hoping someone else had tried.
pwsusi is offline
post #7 of 16 (permalink) Old 01-31-2015, 09:20 PM
There is a guy on ebay who sells the exact same size butterfly latches as on the old cases. Search "ATA butterfly latch." They are not finished like the originals, but they work. I had a case missing two latches. What I did was cut some aluminum rectangles (two for each latch), drill two holes in each, sandwich the case plastic, and rivet them in place. Positioning the backer plate was a pain, but I used some blue tape to hang it and some epoxy to set it. Then I drilled holes for the latches and riveted them in place. It aint pretty but it works well. I think I have about $8 in fixing it.
Fat.Mike is offline
post #8 of 16 (permalink) Old 01-31-2015, 09:22 PM
Hope that helps!
Fat.Mike is offline
post #9 of 16 (permalink) Old 01-31-2015, 09:41 PM Thread Starter
Thanks! Happen to have a larger picture? That one is really small and i'd like to have a better look.
pwsusi is offline
post #10 of 16 (permalink) Old 01-31-2015, 10:33 PM
Here ya go!
I think you could easily paint the plates and exterior of the latch black and the fix would disappear, I was just lazy and happy it worked. Again it isn't the prettiest solution, but I guarantee that it is stronger than a latch rivet through 25 year old plastic!
Edit: Now that I am thinking about this, I think I did epoxy both plates in place. I did that so that wouldn't move around when I drilled the rivet holes.
Fat.Mike is offline
post #11 of 16 (permalink) Old 01-31-2015, 10:49 PM Thread Starter
Thanks Mike!
Here are the latches i'm looking at..
http://www.ebay.com/itm/Small-Surfac...item256f3830a2
Assuming these are the right ones, how did you attach the latch to the front piece of metal. I guess what i was wondering is i could get away with only a piece on the inside and either screw or rivit into that from the butterfly latch like Rich was describing. It looks like with your approach the front piece is required? How did you attach the latch to it?
pwsusi is offline
post #12 of 16 (permalink) Old 02-01-2015, 04:27 PM
Those look like the ones I got, I think that is the same seller too. My thought on the two pieces of metal was that the plastic was brittle, so may as well make a metal sandwich epoxied together for strength and so it doesn't break again. I used rivets to attach the latch. You could do like you are thinking and only use a backing plate. You could even tap the holes in the backer plate and use an 8-32 screw, then no nut on the screw would be needed. I didn't have to take the case foam out, I just pried the case back a little, BTW.
Fat.Mike is offline
post #13 of 16 (permalink) Old 02-08-2015, 05:31 PM
SKB sells replacement latches for their cases, which any good company should. They are most likely very similar to what are on most other cases.
http://store.skbcases.com/keys-latches/
I replaced latches on several cases that came with Japanese made guitars, ( Ibanez, Greco, FGN), for $8.00 per latch. In several instances, I actually went ahead and replaces all 3 latches on a case so I didn't have to do it again later.
merman_93 is offline
post #14 of 16 (permalink) Old 02-08-2015, 05:48 PM Thread Starter
Thanks. Per Fat.Mike's suggestion I bought a latch from ebay; it only cost $2.50 and is just like the original (except the finish is a little different).
Anyway, i installed it this weekend and it's working great. I bought 6 more as i have a few more to do and will have a couple extras just in case.
[IMG][/IMG]
pwsusi is offline
post #15 of 16 (permalink) Old 02-08-2015, 08:16 PM
Looks good. I always prefer to "save a case" when I can.
FS: *** Jem 7dbk w/Hard Shell Case *** angeldef Classified Ads: Ibanez JEM/UV Guitars 5 06-03-2010 06:58 PM
WTB UK: Ibanez hard shell case axemanrio Classified Ads: Guitars and Gear 4 12-15-2009 06:54 AM
FS: New Hard Shell Case for Jackson Dall Classified Ads: Guitars and Gear 2 04-10-2008 10:43 AM
Want to Buy - Tounge latch for UV1000 HARD SHELL CASE, SAME CASE THE JEM SHIPS IN cradleofphil Classified Ads: Guitars and Gear 9 01-28-2007 01:29 PM
M100C hard shell case Dinosaur Gear, Equipment, Recording & Off Topic 3 02-02-2006 12:11 PM
