Help with Cu tape mod - Jemsite
post #1 of 3 (permalink) Old 01-09-2012, 11:20 AM Thread Starter
Hello all,
I tried to use search function but no luck this time.
I considered to shield my guitar cavities with Cu tape for getting minimal hizz-hum. Specially for single coil pup and I have few questions.
Is it possible to successfully mod RG570? I am not sure if separate "Faradays cages" will work, because RG has cavities from front (pups) and from back (pots).
Do I need to fill with Cu also place under tremolo back, and place with springs?
Also having worries, if I should use some kind of non conductive material under pots, because I have feeling the become conductive when sitting on the Cu tape instead of normal wood.
The tape I ordered has conductive glue on itself so there should be no need of soldering the tape?
Also if needed the solder the tape, do I have to solder each piece? or only some place like the sharp angle of cavities.
If you have another tips and tricks and hints, I welcome them.
Thanks to all
Wakizashis is offline
post #2 of 3 (permalink) Old 01-11-2012, 02:57 AM Thread Starter
Re: Help with Cu tape mod
Nobody knows? Am I in the bad section?:-)
post #3 of 3 (permalink) Old 01-11-2012, 03:42 AM
as far as i know there is not a lot to it,
a few tutorials on the web that seem better than anything thats easy to write.
I did a couple, didnt seem to make much difference, and there are issues with ground loops, and insulating the conductor that mean its just as easy to make it worse rather than better.
I know thats not much help, I just dont have anything sensible to say.
LostInRockFormations is offline
copper tape shielding
Painter's tape overload! onetimeoneplace All Other Guitars (including Prestige) 3 04-05-2011 11:02 PM
tape behind pickup? Devon8822 Pickups & wiring 4 02-24-2008 05:21 PM
Petrucci: The Secret Tape guitarsalad14 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 32 10-20-2006 06:57 PM
tape over pickup johank Pickups & wiring 6 10-25-2002 02:47 PM
E-BOW - the guy on the tape Hitman Gear, Equipment, Recording & Off Topic 3 05-21-2001 11:15 PM
