help getting new parts - Jemsite
post #1 of 6 (permalink) Old 01-08-2015, 09:11 AM Thread Starter
So i would like to replace the pots and jack in my 350 and was wondering if anyone could recommend a good push/pull or push/push pot for both the tone and volume and a good reliable jack too if it really matters in the long run. Also who makes good caps? any help would be awesome
MillionthHunter is offline
post #2 of 6 (permalink) Old 01-08-2015, 09:16 AM
Re: help getting new parts
Best push/pull pots I ever tried are the dimarzio ones. Also I had modified the tone one, by opening its wafer and scratching at the end, into a no-load one. Really good.
Be careful as they are ultra hard to solder on them. You might want to engage some kind of tip like presented here : http://guitarnuts2.proboards.com/thr...rzio-type-push
panix is offline
post #3 of 6 (permalink) Old 01-08-2015, 09:22 AM
+1 on the Dimarzio pots.
GUITARMAGEDDON is offline
post #4 of 6 (permalink) Old 01-08-2015, 03:57 PM
RGTFanatic's Avatar
DiMarzio uses re-branded CTS pots and CRL switches.
Dillon, I use this place exclusively: I use oak switches, CTS pro pots, and recently started using the polypropylene caps........I like them so far. The switchcraft 1/4x1/4 jacks work great. They have a nice positive engaging feel. I used one on my RG2XXV.
http://www.guitarelectronics.com/
RGTFanatic is offline
post #5 of 6 (permalink) Old 01-08-2015, 09:08 PM Thread Starter
thank yall for replying but i got one more question, do i need one push/pull for each pickup i want to split and want are the differences between audio and linear taper?
post #6 of 6 (permalink) Old 01-08-2015, 09:37 PM
RGTFanatic's Avatar
You can do what you want without a push-pull. You can do it with a 5-way multi-pole switch. The difference between audio and linear taper is how much signal is left when the pot is turned down to half-way. A linear taper will be 50%, an audio taper will be closer to 35%. most of the signal is affected before 50% travel.
Ibanez jem project parts blow out (loads of parts) jsdisciple Classified Ads: Ibanez JEM/UV Guitars 9 08-17-2011 10:56 AM
FS: Tremol No, Ibanez Parts, Misc parts Severinsteelsmith Classified Ads: Guitars and Gear 3 01-10-2011 04:18 PM
UV7 VWH Project guitar/parts: body, neck, pickups, parts… tobias. Classified Ads: Ibanez JEM/UV Guitars 5 08-23-2008 05:51 AM
WTB WTTF: Jem7RB parts, Any and all parts considered Jem7RB MK Classified Ads: Ibanez JEM/UV Guitars 0 10-25-2004 06:45 AM
