HELP With a js1000 - Jemsite
post #1 of 11 (permalink) Old 01-01-2006, 10:41 AM Thread Starter
Unhappy HELP With a js1000
After i change strings (all in once$!$%) i notice that a difference at my string tension some strings are much easier to bend and fret than others and this make playing difficult .
Anybody can help me guys?
iaosnas is offline
post #2 of 11 (permalink) Old 01-01-2006, 04:20 PM
Re: HELP With a js1000
Have you change guage of string? Also make sure you put the correct gauge in place, for example, did you put a 9 where a 9 should go? did the 16 go where the 16 should go?
Ant1981 is offline
post #3 of 11 (permalink) Old 01-02-2006, 10:09 AM
Remember that every time you change your strings your intonation and action all change and you need to adjust everything again. The only thing changing all strings at 1 time can do is alter your neck tension which in the long run puts more tension on your neck, otherwise its the fact that other things like the action and intonation change each time you change the strings and you need to adjust it. I'm sure its not really a problem with the guitar.
amanvai is offline
post #4 of 11 (permalink) Old 01-02-2006, 12:01 PM
Does this happens on a vintage strat like guitar too?
In mine the intonation didnt changed with the new strings(changed them 1 by 1) but the action is what I want to know about.
THX
einarabelc5 is offline
post #5 of 11 (permalink) Old 01-02-2006, 03:02 PM Thread Starter
Unhappy Re: HELP With a js1000
thank you for your help amanvai.I know how to adjust the action but i don't know how to adjust intonation can you help me?http://www.jemsite.com/forums/images/icons/icon9.gif
Unhappy
iaosnas is offline
post #6 of 11 (permalink) Old 01-02-2006, 03:07 PM
iaosnas, did you change string guage? If not, ignore the advice you have been given - changing string (for the same guage) does not mean you have to set the guitar up again!
However, if you changed guage you will need to do some work.
Algiman is offline
post #7 of 11 (permalink) Old 01-03-2006, 07:39 AM
Lightbulb Re: HELP With a js1000
If you stay with the same gauge the intonation is the same I've found.
If you use D'addario strings you will notice on the back it shows you the tension on the string, if you have customized your own gauge or are using a rare gauge of string this could be the problem, Sat himself uses D'addario EXL 120, this is 9,11,16,24,32,42 I think. So I recommend fitting these into your JS and intonating it- then see if the problem continues, if it does I would go to a guitar expert and ask them. The less tension on the string the easier to bend it is; so there will be slight differences, but not differences that affect your ability to bend the string. It could be the string is a dud, but if this has happened consistently through string sets then I don't know sorry! If you find out what the problem was, please tell us in this thread
Thanks
Regards
Jonny
PacificaJonny is offline
post #8 of 11 (permalink) Old 01-03-2006, 07:42 AM
All strings are harder to bend near the nut by the way, I know it's stating the obvious but if this is the problem then there ain't much you can do! if the strings are noticably different to bend at the same fret then ask an expert!
Regards
Jonny
post #9 of 11 (permalink) Old 01-03-2006, 11:30 AM
Changing strings, so long as you are using the same gauge, would hardly impose a detriment on action, intonation or neck tension. It's most likey to be a different gauge or the wrong strings in the wrong place.
Ant1981 is offline
post #10 of 11 (permalink) Old 01-05-2006, 11:07 PM Thread Starter
It's possible to make the intonation myself without the intonation tool?
iaosnas is offline
post #11 of 11 (permalink) Old 01-07-2006, 08:11 AM
I don't think so, use the allen key and unlock the saddle, then slide it back or forward, and try the intonation again
addario exl , addario strings , intonation tool , string guage , string tension , vintage strat
FS: JS1000 BP JimmySinner Classified Ads: Guitars and Gear 1 05-07-2011 09:54 PM
Looking for JS1000 BP carlos grijalva Ibanez JEM, UV, JS & Other Signature Models 6 07-17-2005 09:49 PM
Wtb Js1000 Btb clar-v-d Classified Ads: Guitars and Gear 1 04-12-2005 04:57 PM
