The jist of my problem is that I'm going to doing some pickup changes on my '99 FP. I'm going to leave the middle pickup and swap the PAF Pros for a Gravity Storm (bridge) and Liquifire (neck). Here is a Jem wiring diagram, which makes perfect sense to me:
The issue is that I like the sound of the Liquifire with the cable exit towards the bridge. This will cause Position 2 to be the middle pickup and the coil closest to the neck. Is there a way to wire this differently so that the coil closest to the middle is active in Position 2?
If not, I don't ever use that position, so I could just pull the stupid switch and replace it with a VLX53.
