Help Needed: My 1st Custom Job - Jemsite
post #1 of 25 (permalink) Old 06-29-2011, 10:59 PM Thread Starter
Hey Jemsters,
I’ve just recently joined up due to my purchasing of my 3rd Ibanez (RG350DX) which I absolutely LOVE!
But reading some of the posts on this site has drawn me to modification, and if its going to be any of my guitars, I suppose it should be my GIO GRG170DX which was a demo stock clearance item for about $150AUD.
I’m aware that my first go at customization may not go incredibly well, but I do want to go the whole hog, and I may need a bit of help from you guys.
As far as painting goes, I think I’m OK, I have some nice ideas and have used the search function and google to help me on my way, thanks to everyone that’s posted great how-to’s.
It's the hardware side that I think I need help with. The pickups are awful in this thing (In fact I don’t think they are working at the moment – I haven’t picked it up in a while) so I was thinking of doing something a bit radical.
I want to take them all out, obviously so I can paint, but while it is stripped, I want to fill the Neck and Middle pickups and only have a bridge (which I’ll probably just use a EMG HZ that I have lying around).
This leaves room for my custom paintjob in the middle, and it looks different to all the rest. I will also be removing the Tone, Volume and Pickup selector switch. I know that people will think I’m crazy, but it will just be a display guitar, that I can play for kicks.
So my questions to the real techies out there are:
1)How do I wire up the pickup to bypass the Volume / Tone / Selector and go straight to the input and does this require any modification to the wood?
2) Will this actually function or should I leave at least the Volume?
3)What is the best ‘filler’ for the pickup holes and any other bits?
If you guys could give me a hand that would be great. I will be keeping everyone updated with my progress once I get a wriggle on.
Thanks all,
Benj
Benj is offline
post #2 of 25 (permalink) Old 06-29-2011, 11:18 PM
Reviews: 3
Re: Help Needed: My 1st Custom Job
Do you mean just have the pickup soldered right to the jack? If so, hot wire goes to hot lug, ground goes to ground. I'd recommend keeping the volume control at least. Seymour Duncan has a wiring diagram for that I think.
IBZshredder is offline
post #3 of 25 (permalink) Old 06-29-2011, 11:36 PM
IBZshredder has it right for wiring straight to output (not input...electric guitars don't have inputs...).
You don't need a volume knob to make a guitar function. Wiring straight to the jack will get your sound to the amp just fine. You'll have no way of stopping it short of turning the amp off or getting a cable with a mute switch or the like though.
I'm reasonably sure that for filing you're best to options are either:
A) Fill with Marine Resin. I believe Linux Penguin has done this and could likely give you more information if he happens to pop into this thread
or
B) Fill with a block of wood. Cut it to the right size, glue it in, make sure the glue seals the cracks between the wood and the body and sand it all smooth and whatnot.
Both are likely to shrink eventually though.
AxeHappy is offline
post #4 of 25 (permalink) Old 06-30-2011, 12:06 AM
Reviews: 11
WHO DOES THIS KIND OF STUFF?! OMG!
ME! lol
Ok. cutting a block of wood and filling it WOULD be ideal, however, not necessary.
Heres some ideas.
I use bondo backed with backing material to fill holes (vol/tone knob holes, stuff like that). It doesnt expand or contract much differently then wood will. I've never had issues with it. For LARGE holes like pickup cavities, I used epoxy resin with great success. It dries super duper hard, and will be impossible to remove, ever. Its a fairly easy process, pending you have some good sanding tools
For the direct wired pickup, you can go to radio shack and buy a 3 dollar SPST switch (on/off) and wire that in series with the hot wire to effectively create a kill switch. No volume knobs required . Hell, you could mount the switch on the back or side and have a totally clean front end of the guitar if you wanted to....
started life like this :
end of life :
And some how I let lerxst6 talk me into striping it EVH style, and I thank him for that hahah
linuxpenguin is offline
post #5 of 25 (permalink) Old 06-30-2011, 12:19 AM Thread Starter
Wow, cheers guys, fantastic feedback. And that looks awesome LP! I'm trying to think of what I'll do with the headstock, but I'm keeping it a surprise...
Now I am throwing around the idea of painting the neck and fretboard. The thing is I want it white so that I can airbrush on some custom inlays... How viable is this?
Oh and what do you mean by 'backing material'?
Thanks again guys
Benj is offline
post #6 of 25 (permalink) Old 06-30-2011, 12:36 AM
I wired up one of my guitars with no pots or switches. You'll get maximum output from your pickup. It works great, but I wish I had at least a kill switch.
Solder white and black together.
Red goes to the output tip. (switch could go between red and tip)
Green and ground (bare wire) go to sleeve.
Trem wire to sleeve.
I'm going to put all the controls back in (and pickup) so it looks better. If it didn't have the maple top, I'd just fill in the holes and swirl it like my other guitar.
xXLinkageXx is offline
post #7 of 25 (permalink) Old 06-30-2011, 12:49 AM
i've used bondo before, but it heavily depends on which kind you use. i only used it because it was readily availible at the time. Glueing in the block of wood is your best bet.
tommychains is offline
post #8 of 25 (permalink) Old 06-30-2011, 02:11 AM Thread Starter
Cheers guys, I'm going to strip the guitar this weekend and just see where everything will go.
I've sourced these some switches, if you search for 'SPST Round Red Illuminated Actuator Rocker Switch' on ebay australia, it'll pop up. Black surround with a red switch (needs to be red for the colour scheme).
Obviously I wont wire up the power for the illumination, but will they be ok? I'll mount it flush probably next to the input jack on the side of the guitar.
I'll just have to drill a 2mm hole straight into the electronics cutout yeah?
Then just wire the pickup to there and the switch to the output jack?
Benj is offline
post #9 of 25 (permalink) Old 06-30-2011, 03:39 AM
Reviews: 98
Bypass the volume pot by soldering the north start lead directly to the jack sleeve lug. Not really sure why you don't want a volume pot--maybe you're using an volume pedal...
AlaskaBat is offline
post #10 of 25 (permalink) Old 06-30-2011, 03:56 AM Thread Starter
AlaskaBat, cheers for that, that'll be a great help! I swear this is the most helpful forum Ive been on!
I don't want a volume because I want the front clean and don't really need it, the guitar is basically a display guitar that I might play every now and again.
I also want to see how it affects the sound, not having to go through a tone or volume pot.
I'm basically starting all this with no experience, basic woodworking / electronics knowledge and no painting experience but Im quietly confident
Benj is offline
post #11 of 25 (permalink) Old 06-30-2011, 04:11 AM
Reviews: 98
Have you been to my wiring thread?
http://www.jemsite.com/forums/f35/an...ad-110579.html
post #12 of 25 (permalink) Old 06-30-2011, 06:39 AM
That switch should work just fine. You could hook up a battery to it and use a stereo jack to light it up when you insert the cable. That is how they turn on active pickups/electronics.
You mean tip.
post #13 of 25 (permalink) Old 06-30-2011, 09:44 AM
I also have filled holes with epoxy resin, simple, and effective.
andrewgosline is offline
post #14 of 25 (permalink) Old 07-01-2011, 01:59 AM Thread Starter
Cool, cheers for that, beginning the stripping down / sanding phase tonight.
AlaskaBat, did you end up writing that ebook on painting guitars? I read in one of your threads where you wer eplugging someone elses, but it was removed due to copyright.
I tried having a look but cant see if you ended up doing it up?
Benj is offline
post #15 of 25 (permalink) Old 07-03-2011, 09:06 PM Thread Starter
1 more post for links...
Benj is offline
custom , grg170 , single pickup
LP Custom Tuner Help needed THE UNIVERSAL ONE Tech: Setup, Repairs and Mods 8 11-02-2010 01:48 PM
Jem/J-Custom opinions needed RiverKing Ibanez JEM, UV, JS & Other Signature Models 14 02-20-2007 03:07 PM
J-custom identification needed vette6600 All Other Guitars (including Prestige) 7 11-19-2006 01:52 PM
Custom Paint job needed? snakecharmer All Other Guitars (including Prestige) 3 03-09-2006 01:35 PM
Help needed on Custom Guitar Project!!! zEr0 Tech: Setup, Repairs and Mods 9 01-01-2005 07:03 AM
