Help! Pickups sound weak? Is it just my setup? - Jemsite
post #1 of 16 (permalink) Old 04-26-2008, 06:46 PM Thread Starter
I've used rack systems and emg's for a long time.
Today I wired some Dimarzio's into an RG1570 and tried them through my rack presets. But they came out a bit weaker than the EMG's and the noise gates ate them up considerably quicker than they would my EMG's.
Are the dimarzio's just weaker outputs or did I do something wrong? I know I wired them right. Green and ground to ground and red to switch.
They sound pretty normal but they just distort pretty limply compared to my EMG's. Do I just need to adjust the gain and noise gate parameters in my rack?
For the record, I have tried other pickups through the same setup (tom andersons mostly) and they don't do this. It's weird.
jbandy10 is offline
post #2 of 16 (permalink) Old 04-26-2008, 07:01 PM
Re: Help! Pickups sound weak? Is it just my setup?
Which EMGs are they? EMGs are typically pretty high gain, so that might be the issue.
waylay00 is offline
post #3 of 16 (permalink) Old 04-26-2008, 10:41 PM
I assume you adjusted the pickup height, properly, right?
Racerx2k is offline
post #4 of 16 (permalink) Old 04-27-2008, 12:28 AM Thread Starter
I have used all the emg's (60, 81, 85)
The height is pretty normal. The signal just seems a lot weaker than everything else I've used.
Is it possible that I didn't ground them good? Would that even be the issue?
jbandy10 is offline
post #5 of 16 (permalink) Old 04-27-2008, 02:59 AM
Reviews: 7
I use passives and my other guitarist uses EMG's. When he plugs his guitar into my rig it doesn't change the volume noticeably. It also works the other way around, when I plug into his gear the volume is so close you can't tell the EMG's are higher output.
Also never had to do any tweaking on my setup between active and passive pup's.
brothersnowgone is offline
post #6 of 16 (permalink) Old 04-27-2008, 03:17 AM
I guess it could depend on what type of Dimarzio's you've put into your 1570. Is the weak issue on all positions of the 1570? Have you tested that the proper coils are working per switch position?
Ibateur is offline
post #7 of 16 (permalink) Old 04-27-2008, 09:16 AM Thread Starter
Yeah it's all 3 pickups. And they are high gain pickups. I'm thinking Something got wired weird. Which doesn't make sense cause I wire them all the time.
jbandy10 is offline
post #8 of 16 (permalink) Old 04-27-2008, 09:28 AM
Ok, you really need to be specific as to precisely which Dimarzios you have just installed.
toneboy is offline
post #9 of 16 (permalink) Old 04-27-2008, 12:12 PM Thread Starter
I just realized what the problem was.
I ordered regular spaced when I needed F-spaced. The poles are totally off.
Do you think Dimarzio will let me do an exchange?
jbandy10 is offline
post #10 of 16 (permalink) Old 04-27-2008, 04:08 PM
axemanrio's Avatar
I doubt standard spacing would cause a major issue like you have described. What pickups though?
axemanrio is offline
post #11 of 16 (permalink) Old 04-27-2008, 04:13 PM
Spacing will definitely not make that much difference. To repeat the questions above- which Dimarzios have you installed?
Algiman is offline
post #12 of 16 (permalink) Old 04-27-2008, 04:22 PM
axemanrio's Avatar
Maybe they're DiMarzio/ibz pickups?
post #13 of 16 (permalink) Old 04-27-2008, 06:16 PM Thread Starter
No.
Neck is a breed. Middle is an air norton s. Bridge is a Super 3.
jbandy10 is offline
post #14 of 16 (permalink) Old 04-27-2008, 07:02 PM
I've had problems like that before and usually it was just that the pickups I was putting in needed one of them to be reversed in the wiring. The first time I wired the RG 550 it came out terrible or where only one sounded right. I just kept researching and switching things around until I got it right. The folks at DiMarzio are supposedly really great at helping you wire things right, but I've never had to call them.
You might need better pots or capacitors also... just a thought.
Silver Sable is offline
post #15 of 16 (permalink) Old 04-27-2008, 07:19 PM Thread Starter
Okay this is odd!
I got a hold of an F-spaced PAF pickup and another stacked single to install and test.
I wired the F-spaced in place of the breed and it is WAY louder than the other two! So then I thought...well why is the stacked single coil not loud if it doesn't need to be f-spaced?
I put the other one in there and it's louder... WTF. Something must have been wired wrong. I'm lost.
jbandy10 is offline
air norton , pickup height , rack pre , rack system
How's this setup sound? tomkatzz All Other Guitars (including Prestige) 0 04-03-2007 09:54 PM
pickups - looking for a warm jazz sound for a mahogany/maple trajectory fish Gear, Equipment, Recording & Off Topic 7 12-17-2001 08:45 AM
I FOUND MY SOUND!!! - And i wanna share it with you! armindo__dias Gear, Equipment, Recording & Off Topic 7 06-01-2001 12:32 AM
Help! New pickups in JS100 Sound bad? - PAF pro and Fred sou Voodoosoup Ibanez JEM, UV, JS & Other Signature Models 6 03-27-2001 08:27 PM
5150 setup - making the 5150 half sound more like Vai Allen Lee Tech: Setup, Repairs and Mods 7 02-28-2001 05:58 PM
