Help on removing trem post inserts - Jemsite
post #1 of 3 (permalink) Old 05-10-2003, 10:32 AM Thread Starter
What is the best way to remove the trem post inserts from a body?
I believe they are press fit in the body so I assume some sort of brute force method is needed.
Any help or suggestions are appreciated! thanks.
Entropy is offline
post #2 of 3 (permalink) Old 05-10-2003, 12:02 PM
Why are you pulling them?
Whatever the reason, I use a cats paw. Lay some shims across the body to use as a base and protect the finish [I actually put the shims on top of a cloth] and then just pull them straight up. You'll have to cut away all the paint that covers the top edge of the inserts or you'll rip a bunch of it up, alot more than if you trim it around the insert.
Rich is offline
post #3 of 3 (permalink) Old 05-11-2003, 08:51 AM Thread Starter
Thanks, Rich.
The reason I'm thinking about doing it is that in one hand I have a body with no hardware and in the other hand I have a full guitar to cannabilize for it's hardware.
Entropy is offline
WTB Locking trem post inserts for Original Edge Toca Classified Ads: Guitars and Gear 0 05-09-2012 10:39 AM
how do you remove old trem post inserts dazzer All Other Guitars (including Prestige) 16 07-12-2011 05:30 AM
Recessed Floyd Post Inserts Question LionsClaw Tech: Setup, Repairs and Mods 5 07-28-2008 09:44 AM
Trem post inserts - What is the diameter? bammbamm Tech: Setup, Repairs and Mods 4 03-11-2008 12:08 PM
Removing post inserts . Zoot Tech: Setup, Repairs and Mods 4 11-01-2007 06:39 PM
