Help with signal chain - using rack unit AND pedals - Jemsite
post #1 of 5 (permalink) Old 01-07-2012, 11:30 AM Thread Starter
Hey guys,
I have question weather or not it's possible for a rack effects unit to be able to be utilized with a flanger pedal put after it in a signal chain (i.e. output of the effects unit into the pedal, pedal out into a looper pedal, then the loop pedal out back into effects return loop of amplifier). What I mean is will I be able to use a current preset on my effects AND be able to add in the flanger effect of the pedal as well without affecting the preset effects (other than, of course, having the extra flanger turned on)? I'm looking at adding another type of flange than the one in my effects unit. Thanks in advance.
Tannen is offline
post #2 of 5 (permalink) Old 01-07-2012, 02:07 PM
Re: Help with signal chain - using rack unit AND pedals
You could always leave the rack FX in the loop and put the flanger between the guitar and amp.
therightjem is offline
post #3 of 5 (permalink) Old 01-07-2012, 02:50 PM
I would try it and see.
I have used a couple of flangers before my MultiFx unit,
Sounded like flangers but then I dont really like them so cant say it was great for me.
I thought the point of flangers was to get a weird spacey noise,
if its messd up it will just be more weird = far out man.
LostInRockFormations is offline
post #4 of 5 (permalink) Old 01-07-2012, 04:26 PM
Reviews: 10
This is exactly what I would do too...I just got a flanger for Christmas (mxr micro-flanger) and I tried it in my effects loop but it sounded better when I placed it between the guitar and the input of my amp...
doriangrey is offline
post #5 of 5 (permalink) Old 01-07-2012, 06:29 PM Thread Starter
I think I'll try it before the FX loop when it comes in. Great advice guys. I'm just hoping that I will still be able to take advantage of, say, my noise reduction option from my effects unit and that it will still work when the flanger is engaged.
Tannen is offline
effects unit , flanger , signal chain
Need help with signal chain Tannen Tech: Setup, Repairs and Mods 2 03-15-2010 02:53 PM
How many pedals can you chain without signal booster? GLG421 Gear, Equipment, Recording & Off Topic 6 06-24-2009 04:35 PM
Signal Chain... chaos731 Gear, Equipment, Recording & Off Topic 20 08-12-2008 01:39 PM
BAMMBAMM, How do you connect your rack wah in signal chain? megadeth Gear, Equipment, Recording & Off Topic 9 09-10-2007 10:12 PM
Rack signal chain question - splitting signal to tuner luther Gear, Equipment, Recording & Off Topic 4 12-14-2000 11:06 AM
