Help - TOP LOCK III W/42MM NUT UV7 MODEL - Jemsite
post #1 of 3 (permalink) Old 09-24-2004, 05:21 AM Thread Starter
Hey guys, i have a UV97BK and i have a problem.
On the Low B and Low E - the top lock has threaded (not the pad screws, where it actually screws into), i can't tighten it at all
now, i guess i have to get a new top lock?? and if so, how hard of a job is it to do it yourself?
please help
EDIT - sorry i posted in the wrong forum, it should be in the Tech/repair forum, id move it or delete this one, but im not sure how, sorry for being such a newbie
Universe System is offline
post #2 of 3 (permalink) Old 09-24-2004, 07:12 AM
dex
You will need to get a lock nut base at least and if I were you I'd email Rich (swirly banner above) for the part.
Swaping it is not hard at all, it can even be done without changing strings.
Just undo all 4 lock nut bolts all the way and remove them with the pressure pads, dive the trem half the way and stick a plastic bottle cap or something (I do 9v battery) under the trem in the cavity to keep it slightly dived.
Now unwind the strings a bit from the tuners (about a turn should do) and unscrew the top lock bas from the back of the neck.
Place the new one in and do everything back in reverse.
ilia
dex is offline
post #3 of 3 (permalink) Old 09-24-2004, 10:06 AM Thread Starter
thanks mate
since im in Australia, ill try to get it locally, and if not ill try Rich (he doesn't seem to have any in stock atm)
lock nut
WTB: 1986 Top Lok III nut in black 42mm Plow72 Classified Ads: Guitars and Gear 1 01-14-2013 11:46 PM
dimarzio set 42mm or 43mm for les paul? bklixuz Pickups & wiring 3 07-16-2012 02:22 AM
Gibson Axxis Floyd Rose black w/ 42mm brass sustain block Getcha pull Classified Ads: Guitars and Gear 0 06-21-2012 01:12 PM
Replacing Dimarzio Clip Lock With Dunlop Strap Lock EEF13 Gear, Equipment, Recording & Off Topic 3 12-20-2011 05:51 AM
String Lock Block fell from 350DX model. IsaisJ Archived Topics and Common Questions 2 11-04-2011 09:44 PM
