How can a 25.5" Jem feel looser than a 25.0" PRS? - Jemsite
post #1 of 20 (permalink) Old 02-28-2015, 12:43 PM Thread Starter
Reviews: 13
I'm totally confused, questioning my own sanity here.
Currently I have in front of me a Jem 7VWH and a PRS Custom 24 with the PRS tremolo. Scale lengths: Jem is 25.5", PRS is 25.0". Same string gauge & brand, same setup (I did both), both tuned to EADGBE, intonation correct.
The physics say that the PRS, having a shorter scale, should have the strings with less tension in order to compensate the shorter string length. PRS should have looser strings, period. However, playing one after another, they seem to have the same string tension under my fingers... sometimes I have the impression that the Jem is easier to bend!
Can someone give me any theory about this phenomenon??
Rachmaninoff is offline
post #2 of 20 (permalink) Old 02-28-2015, 01:22 PM
Re: How can a 25.5" Jem feel looser than a 25.0" PRS?
If they both had fixed bridges the PRS would be easier to bend.
What you're feeling is due to the trems.
wilch is offline
post #3 of 20 (permalink) Old 02-28-2015, 01:24 PM
floating trem on the Ibanez, non floating on the PRS.
panix is offline
post #4 of 20 (permalink) Old 02-28-2015, 01:27 PM Thread Starter
Reviews: 13
I suspect it's a trem issue... but what?
The PRS trem is set to float.
post #5 of 20 (permalink) Old 02-28-2015, 01:46 PM
The design of the trem. It's not an "issue" really, just a result of the design of the different trems.
e.g. The edge has pivots on two knife edges, whereas the PRS (even though it's floating) has 6 screws to pivot on.
wilch is offline
post #6 of 20 (permalink) Old 02-28-2015, 01:58 PM
Reviews: 3
Fret size, wood type, neck bow, width and profile also have its influence, along with the trem design and spring tension.
vy100 is offline
post #7 of 20 (permalink) Old 02-28-2015, 03:21 PM
1. When you lock nut, you can cut off guitar head. So length of the string after locked nut, doesn't mater, same thing on the bridge, Jem's bridge has less string in itself, so in locked Jem you have to measure string length from nut to bridge, and in PRS from post to string ball,
2. Stiffness off springs can be different even in same type of guitars, so one Jem could be much stiffer then other, my LoPro Edge is much stiffer then my Edge Pro so I asume thet even shape of bridge can make difference.
3. angle of tremolo, ( if tremolo is slightly up, strings would have less tension,)
4. Higher action means higher tension.
peromucho7 is offline
post #8 of 20 (permalink) Old 02-28-2015, 03:58 PM
None of the stuff that was mentioned really matters. What matters is break angle over the bridge saddles. Google it. That's why some folks like top loading bridges. Less break angle = looser feel. See http://www.frudua.com/guitar_strings_tension.htm for a write-up.
tomibanez is offline
post #9 of 20 (permalink) Old 03-01-2015, 12:15 AM
This would be argument for the opposite case, since in the jem there are simply no non-vibrating parts of the string, neither on nut side (locking), nor on bridge side (locking). So by frudua's theory (which is btw correct), the Jem should be stiffer than the PRS.
As mentioned, spring flexibility, type, material, length, number of them, could be a factor, angle could be a factor.
Something that was not mentioned, is that a standard vintage strat trem, 6-screw type, will still put more friction on the movement than a trem which was designed for full floating playing trem virtuosos.
panix is offline
post #10 of 20 (permalink) Old 03-01-2015, 01:06 AM
I get this feeling on some guitars. It is because they aren't set up right. Have the PRS professionally set up.
The combination of straightening out the neck by adjusting the truss rod, setting saddle height, adjusting intonation and setting your trem's angle/tension should fix all this.
j.arledge is offline
post #11 of 20 (permalink) Old 03-01-2015, 01:10 AM
I mentioned this earlier.
Grab a string, bend the note up a few semitones and watch the Edge trem tilt forward significantly, and easily.
Do the same on the PRS and the trem probably won't move as much.
wilch is offline
post #12 of 20 (permalink) Old 03-01-2015, 01:30 AM
By all of your logic any fixed bridge should feel more stiff than any guitar with a trem on it. This isn't the case.
post #13 of 20 (permalink) Old 03-01-2015, 01:43 AM
I'm talking specifically about this case. The OP mentioned he has a 25" scale length feeling like it has more tension than a guitar with 25.5" scale length.
I know for a fact that my fixed bridge RG has more tension than my lo-pro edge RG and my Jem. All have a 25.5" scale length, all are basswood with maple and rosewood neck/fretboard.
What's the difference in that scenario? The trem.
What's the difference in the scenario mentioned by the OP? The scale length and the trem, with the caveat that the guitar in this scenario with shorter scale length feels like it has more tension.
Seems logical to me. *shrugs*
wilch is offline
post #14 of 20 (permalink) Old 03-01-2015, 01:43 AM
true, lets say I added some words to your previous thought.
panix is offline
post #15 of 20 (permalink) Old 03-01-2015, 08:55 AM
I believe that this can only apply to fixed bridge, non-locking systems. You can consider the portions of the strings past the nut and saddles to be springs. A greater break angle translates to attaching stiffer "springs" to either end of the main portion of the string. So in the case of the PRS, this would only affect the nut end of the guitar. That said, any string angle at the headstock should be less stiff than a locking nut, which is effectively like attaching the string to a wall.
As far as floating trems, the only explanation that holds any water scientifically is that the geometries of the two trems are very different. We're talking about torque, or force times distance. In any floating trem, the tension in the strings is balanced by the tension in the springs.
In any example, the tension in the string is a constant at a given pitch and scale length. But in order to calculate the force required in the springs, you'd need to know where the center point is that the trem is rotating around and then know the distances to both the saddle as well as the spring attachment point. Depending on what those distances are, the PRS might have more spring tension despite having a shorter scale length, since scale length is only one of the variables.
In two different trem systems, the result of bending a string will result in two different force curves, which we interpret as different feels.
Takin' a Ride is offline
jem 7vwh , prs custom 24
How come some guitar necks feel "dry"? ironfistx All Other Guitars (including Prestige) 7 05-08-2012 03:48 PM
A song with Vocal - Abandoned Place ( "I Feel the Rain") dimitar Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 3 08-12-2009 07:35 PM
ever see a "JS1000" with black gloss, no "satch" inlay and a "J" ser. # IKE560 Ibanez JEM, UV, JS & Other Signature Models 2 04-11-2009 03:05 PM
Ok, I feel silly for asking, but what is "GAS"? Darin All Other Guitars (including Prestige) 22 01-03-2007 09:03 PM
Guitar "feel" IVsakeN Tech: Setup, Repairs and Mods 10 07-15-2003 04:56 AM
