How can you boost a guitar? - Jemsite
post #1 of 12 (permalink) Old 01-23-2006, 05:15 PM Thread Starter
Question How can you boost a guitar?
Hi, I have 2 Dimarzio air classics and a Dimarzio blue velvet single coil (low output) I was wondering, is there any way of boosting my output without changing my pickups or using pedals? See I like to take my guitar to guitar shops and play it through different amps, but it just sounds crunchy even with a mesa triple rectifier up full. I don't wanna be humpin pedals about or changing my sound as I love my tone, I just wanna push it to a higher output, is this possible? Thanks
Regards
Jonny
PacificaJonny is offline
post #2 of 12 (permalink) Old 01-23-2006, 05:40 PM
Re: How can you boost a guitar?
Built in boost circuit, similar to the Clapton Strat mid boost?
Why not just put a boost pedal in your gig bag/guitar case? It isn't a lot of kit to carry about. Most guitar shops will probably have one you could borrow anyway.
Algiman is offline
post #3 of 12 (permalink) Old 01-23-2006, 05:43 PM Thread Starter
Could I get a guitar tech to fit me one of those??? Would it change my tone at all???
Thanks
Regards
Jonny
post #4 of 12 (permalink) Old 01-24-2006, 01:29 AM
Moving your pickups closer to the strings increases output a bit more, but you can always just shove a booster unit into your guitar. If you're good with a soldering iron and simple electronics, you can build your own mini booster unit. (you can also get higher output pickups like an Air Zone or Tone Zone)
Personally, I would still use a Tubescreamer, SD-1 or some other overdrive pedal into the frontend of my amp. Do note that you can usually mod a cheap distortion/overdrive pedal into a clean(er) boost pedal but swapping out the diodes.
buddroyce is offline
post #5 of 12 (permalink) Old 01-24-2006, 04:03 PM
Thanks
Regards
Jonny
Yes, and yes. They are dead easy to fit, and they will change the tone a bit - which you may or may not like.
Buy a tubescreamer.
Algiman is offline
post #6 of 12 (permalink) Old 01-24-2006, 04:05 PM
try a bbe sonic max or a pickup booster
guitarshredder7 is offline
post #7 of 12 (permalink) Old 01-24-2006, 04:22 PM
what's wrong with having a boost pedal? At least with a pedal you can use it with any guitar you have. If you just put a boost circuit on your guitar you can only use it on that guitar. Pretty lame if you ask me.
RSVampire is offline
post #8 of 12 (permalink) Old 01-24-2006, 07:33 PM
ya boost pedals can be useful
guitardevil2005 is offline
post #9 of 12 (permalink) Old 01-24-2006, 07:39 PM
elcid's Avatar
Are you sure the pickups are working right?
I had an HS-3 in a strat that barely broke up on a hi gain head and it turned out the pick up was bad.
You may have a loose wire or something.
elcid is offline
post #10 of 12 (permalink) Old 01-25-2006, 11:24 AM Thread Starter
Next time I'm at my music shop I'll be sure to have it checked out, thanks for your advice everyone!
Regards
Jonny
post #11 of 12 (permalink) Old 01-27-2006, 02:15 PM Thread Starter
I think theyre ment to be like that, It's ok now though coz I can use my boost pedal, cheers dudes!
post #12 of 12 (permalink) Old 01-27-2006, 02:18 PM
Did you get a straight up boost pedal or did you modify an overdrive/distortion one?
ChopTart is offline
bbe sonic , boost pedal , dimarzio air , dimarzio blue velvet , guitar shop , guitar tech , mesa triple rectifier , output pickup , overdrive pedal , tone zone , triple rectifier
My clean boost pedal in my FX Loop doesn't boost volume? julzius Gear, Equipment, Recording & Off Topic 23 06-18-2013 01:34 PM
Do you Boost? shogun Gear, Equipment, Recording & Off Topic 24 08-08-2007 10:11 PM
What's your boost? StevenMikel Gear, Equipment, Recording & Off Topic 26 07-26-2007 11:56 PM
DS-1 as a boost? IbanezPrestigeBoy Gear, Equipment, Recording & Off Topic 17 02-16-2004 06:25 PM
Looking for a boost... Jammy Gear, Equipment, Recording & Off Topic 4 01-20-2003 12:47 PM
