How to clear over enamel paint??? - Jemsite
post #1 of 18 (permalink) Old 02-27-2012, 12:47 PM Thread Starter
Two questions...
I`m just wondering how you guys clear over enamel after doing a swirl? I need to know before I decide what paints to use. So far I`m thinking Testors, but I also have some Tremclad mixed to the colours that I like and it worked well on some test pieces.
If I cant clear over oil base enamel such as these paints, do automotive paints work to swirl? I know I wont have trouble with the clear this way. Or is there another option for clear other than automotive? Three questions i guess...
Thanks!
Chops.
chopstix21 is offline
post #2 of 18 (permalink) Old 02-27-2012, 04:33 PM
Re: How to clear over enamel paint???
Well, the general rule is to match the type of clearcoat to the type of finish. So if you've used enamel paint, get a clear gloss enamel. Simple, right, or am I missing something?
Peace
Mike
Hikey Mikey is offline
post #3 of 18 (permalink) Old 02-28-2012, 08:41 AM Thread Starter
Peace
Mike
Cool, I found some oil base clear last night, Tremclad, I didn`t even know there was such a thing. It`s in a rattle can tho, I`d rather run it thru a gun....
Thanks Mike!
Chops
post #4 of 18 (permalink) Old 02-28-2012, 10:34 AM
You can use a 2k poly clear, make sure you lightly dust the first few coats on, leave about 10 - 15 min between coats. once its covered then you can start caking it on.
jonnyboy mills is offline
post #5 of 18 (permalink) Old 02-28-2012, 10:40 AM Thread Starter
That`s what I`d like to do! Thanks!
post #6 of 18 (permalink) Old 02-28-2012, 12:12 PM
Would that be from a spray gun and compressor ? Never used the stuff but the results look good .
Zoot is offline
post #7 of 18 (permalink) Old 02-28-2012, 12:55 PM
Yep. always,because you have to mix the two components (2K) together.
Death.by.G-string is offline
post #8 of 18 (permalink) Old 02-28-2012, 04:04 PM Thread Starter
Wow if I can get mine to turn out this nice with Krylon, it might be worth a shot!!!
Check out the picture of the blue one.
http://www.jemsite.com/forums/f21/uv...t=DIY+painting
post #9 of 18 (permalink) Old 02-28-2012, 05:02 PM
that would be mine LOL, and Krylon Fusion is the bomb just dust the first few coats then your all clear for building it up, I use about 3 cans for a guitar body
ibanezcollector is offline
post #10 of 18 (permalink) Old 02-29-2012, 08:43 AM Thread Starter
Too funny! Well thanks for that! 3 cans is about what I figured. Good job man! I`ll be using Humbrol for my swirl, with the Krylon Fusion work for this?
Thanks!
post #11 of 18 (permalink) Old 03-27-2012, 09:26 PM
I wouldnt throw any Clear on Enamel if it was less than 12 months old.
Fully cured Enamel can be cleared with ACRYLIC only.
Thanks.
ozjem is offline
post #12 of 18 (permalink) Old 03-27-2012, 09:29 PM
not true at all, you can also clear with Lacquer. Just got to mist the first few coats.
painters tip
L. E. A.
Lacquer Enamel Acrylic
you can put Lacquer on Enamel with no issues
you can put Lacquer on Enamel and Acrylic with no issues
you cant put Acrylic or Enamel on Lacquer
etc
best tip anyone has ever given me. LEA remember it..
post #13 of 18 (permalink) Old 03-27-2012, 09:35 PM
I have thrown Acrylic Lacquer over fully cured Enamel for over 20 years.
Not one single reaction.
Like the idea of the LEA though.
ozjem is offline
post #14 of 18 (permalink) Old 06-03-2014, 06:00 PM
Talking Re: How to clear over enamel paint???
I'm resurrecting this thread because I'm getting ready to pull the trigger and finally attempt a guitar build this summer. I consult the google for research, and where does it point me? Right back here, where I may have just answered my own question regarding enamel paints . . . two years ago.
Turns out if you search for "enamel paint guitar," well, here we are on the first page of results returned by google.
Laughing and shaking my head at the irony.
post #15 of 18 (permalink) Old 06-03-2014, 06:16 PM
I tried to do a swirl with Testor paint an it didn't work. After, I went on the internetz and found that Testors are not recommended for swirls.
GUITARMAGEDDON is offline
Im never using paint to clear coat again. linuxpenguin Tech: Setup, Repairs and Mods 31 06-13-2011 08:13 AM
Paint/clear melted with heat... help Guiatarded Tech: Setup, Repairs and Mods 8 09-01-2010 03:43 PM
Polyuranthane clear on Enamel paintjob RG462 Tech: Setup, Repairs and Mods 1 10-19-2007 04:40 PM
Any good Clear Paint for my Alumina pickguard??? JEM10th Tech: Setup, Repairs and Mods 2 07-03-2003 06:33 PM
Removing Clear coat and paint Gresh Tech: Setup, Repairs and Mods 9 08-19-2002 11:01 AM
