How to determine if a pickup is faulty? - Jemsite
post #1 of 8 (permalink) Old 12-24-2005, 01:10 AM Thread Starter
well, i suspect it's a malfuction of my neck pickup, it is a stock V1..when i switch the selector all the way towards the neck, there's this wuzzy sound, especially the low E, A and D stings.. but if i switch it all the way the other direction, the wuzzy sound is gone..the wuzzy sound is so bad that the tuner cannot even register the note..(i tried it with a bypass too..) is my pick up spoilt or sumthing?
kelvin55 is offline
post #2 of 8 (permalink) Old 12-24-2005, 06:19 AM
Re: How to determine if a pickup is faulty?
Does it buzz when you choose the 2nd position of the switch which selects both the neck pickup and the middle one. I assume your guitar has 3 pickups.
klp2332 is offline
post #3 of 8 (permalink) Old 12-25-2005, 07:41 AM Thread Starter
i'm just using stock V1 and V2 pups..i dun have a third one..just 2..
kelvin55 is offline
post #4 of 8 (permalink) Old 12-29-2005, 08:07 AM Thread Starter
no one to offer anymore suggestions? will be greatly appreciated..
kelvin55 is offline
post #5 of 8 (permalink) Old 12-29-2005, 08:46 AM
The V1 probably is faulty. The way you explained the "buzz" in the neck tells me that it's not working correctly. How to determine if a pickup is faulty, I'm not sure. It could be your guitar cable or amp speakers, not so much the pickup. See if your guitar cable and amp speakers are working correctly. If they are working correctly and you still have a "buzz" sound, I'd recommend getting your pickups (neck and bridge) replaced with new ones. DiMarzio is a good brand for pickups. Seymour Duncan is another good brand for pickups. I really do hope this helps.
Here's the DiMarzio Website
Here's the Seymour Duncan Website
bonehead189 is offline
post #6 of 8 (permalink) Old 12-29-2005, 08:52 AM
I'd try cleaning the switch with contact cleaner before doing anything else.
Rich is offline
post #7 of 8 (permalink) Old 12-29-2005, 03:06 PM Thread Starter
realised it only happens when i depress the 3rd fret of the E string and then i pluck the A string simultaneoulsy, the sound goes like "bong bong bong wong wong wong"..and this also happened when i tried my guitar on my friend's amp..the cables and amps are all working correctly..and the selector switch is all the way towards the neck..a point to note is that this dosent happen when i push the selector switch to the other end.. besides that, i adjusted the pickup to the bottom and realised the crazy sound is still there, albeit softer..so is it my pickup? or some other issues?
kelvin55 is offline
post #8 of 8 (permalink) Old 12-31-2005, 07:35 AM
Could be your pickup, quite an unusual one though, or the switch. As Rich suggests, try some contact cleaner. In general, make sure strings dont touch the pickup, check the wiring, and if nothing helps then I guess a new pickup might be what your guitar needs.
Ant1981 is offline
neck pickup , seymour duncan
Faulty Pickup switch issues Simon7VWH Tech: Setup, Repairs and Mods 7 12-14-2013 08:27 AM
Wtb: wanted LNG 777 Jem, yeah I know they are rare but I'm determine to find one cammclellan Classified Ads: Ibanez JEM/UV Guitars 9 12-19-2010 07:37 PM
Can you help me determine a value?? ahoffman All Other Guitars (including Prestige) 10 08-04-2006 10:08 PM
Faulty RG tone pot Shredder87 Tech: Setup, Repairs and Mods 5 07-13-2006 03:23 AM
How do I determine my RG570s year of mfg? djq All Other Guitars (including Prestige) 1 02-17-2005 01:09 PM
