How to have a softer trem action on Original Edge, Help please - Jemsite
post #1 of 24 (permalink) Old 09-18-2015, 11:24 AM Thread Starter
Unhappy How to have a softer trem action on Original Edge, Help please
Hi, It's me again, hope not to bother with my questions, I have an Ibanez Jem 7VWH with an original edge recently installed by a luthier and I would like to learn the secret on how to get a nice setup of that tremolo, I read the ibanezrules section about if a trem is stiff, maybe I'm understanding it wrong cause it says that If I want a softer trem bar action it says "The more closed a spring is, the more force it takes to get it open" Does "open" there means an stretched spring? Cause I'm trying this but not getting it less stiff with 3 springs
(I like to use the trem like Vai and It looks like his trem is really soft and watching pics of the back of evo it has 3 springs, Please If somebody can help me, maybe send me a PM or something
ritchwie is offline
post #2 of 24 (permalink) Old 09-18-2015, 12:48 PM
Re: How to have a softer trem action on Original Edge, Help please
Honestly man, what you are looking when you see Vai play with the trem is not softness but years of experience with the floating trem, everything he plays he make it seem effortless and fluid.
Rafafas is offline
post #3 of 24 (permalink) Old 09-18-2015, 12:58 PM Thread Starter
Yep but then again I like to know how to do it, When my luthier did it last time I felt it really soft, but I want to learn how to do it myself, real help anyone?
ritchwie is offline
post #4 of 24 (permalink) Old 09-18-2015, 06:14 PM
Vai has got his taped-on backcover full with cloth to reduce flutter and tension
morien is offline
post #5 of 24 (permalink) Old 09-19-2015, 01:50 PM Thread Starter
Thanks for that but I've already done this, then again,How can I achieve to have a softer trem action?is it the angle? the springs?height? My original edge is new btw, help anyone :/
ritchwie is offline
post #6 of 24 (permalink) Old 09-19-2015, 02:13 PM
^^^ string gauge, apparently. Get daddario 9-42, and it'll be soft like butter.
panix is offline
post #7 of 24 (permalink) Old 09-19-2015, 02:15 PM
full of cloth to reduce flutter and tension....
panix is offline
post #8 of 24 (permalink) Old 09-19-2015, 02:33 PM Thread Starter
Thanks I have Ernie Ball 9 - 42 strings, any other tips
ritchwie is offline
post #9 of 24 (permalink) Old 09-19-2015, 03:06 PM
Is your trem plate parallel to the body?
if yes then play a floating trem guitar with 10s and then come back to this one.
9s are too light already. BTW
panix is offline
post #10 of 24 (permalink) Old 09-19-2015, 03:13 PM
Try using 2 springs, that will open them up and loosen up the works a little bit... it won't make you Steve though
Swirltop is offline
post #11 of 24 (permalink) Old 09-19-2015, 03:21 PM
won't that require driving those spring screws too deep and potentially either enlarge the thread or create fatigue in the soft basswood? So in case he wants to go back to 3 springs with shallower screw depth, the basswood won't be strong enough for adequate purchase of the screws?
Of course that won't be a problem if the OP just wants to do an experiment and keep it there, the problem will be when starting doing this repeatedly.
panix is offline
post #12 of 24 (permalink) Old 09-19-2015, 03:35 PM
No, shouldn't be a problem at all. I do with 9's all the time
Swirltop is offline
post #13 of 24 (permalink) Old 09-19-2015, 04:36 PM
hmm ok..... screwing/unscrewing in maple (neck screws) *does* create a problem after some iterations. In basswood it can be only worse. Theoretically. But the OP is not there yet, by no means.
panix is offline
post #14 of 24 (permalink) Old 09-19-2015, 06:22 PM
lol... I didn't say he could do it 50 times
It won't hurt a thing if he does it once to see if the trem action feels better
Swirltop is offline
post #15 of 24 (permalink) Old 09-20-2015, 01:01 AM
If you want softer tremolo, small help is to put tremolo from neutral position in slightly raised position.
But if you want really softer tremolo you have use it. If you stretch springs regularly when you broke them in they will become softer. If you have soft springs and you do not use them they can become stiffer.
peromucho7 is offline
ibanez jem 7v wh , original edge tremolo
Original Edge, too low action! yzerman All Other Guitars (including Prestige) 14 04-03-2014 02:53 AM
Lowering action on edge pro trem pdavid Tech: Setup, Repairs and Mods 2 11-29-2008 05:43 PM
FS: Original 80s/90s beat-up 'cosmo' Japanese Edge trem arm (nice loose swing action) lewis.mann Classified Ads: Guitars and Gear 1 08-11-2008 10:34 AM
RG20th Original Edge Action Question quiksilverdew Tech: Setup, Repairs and Mods 16 06-12-2007 02:11 AM
FT: Black Cosmo Lo-Pro Edge Trem for your Chrome Lo-Pro or Original Edge Trem parker_fly Classified Ads: Guitars and Gear 4 02-19-2005 03:18 PM
