How to make a mirror pickguard - Jemsite
post #1 of 7 (permalink) Old 03-06-2003, 03:53 PM Thread Starter
Reviews: 12
I was wondering if anyone can help me on how to make a black mirror pickguard fit for a UV.
Reg
reguv760 is offline
post #2 of 7 (permalink) Old 03-06-2003, 04:13 PM
EKG
Do you have an original UV guard to go from?
You need:
1 Original or template
New material
Router
Drill
Countersink
Spacers and screws to offset new material from template
EKG is offline
post #3 of 7 (permalink) Old 03-06-2003, 06:05 PM Thread Starter
Reviews: 12
Yep... I'll just have to pry it out from my GR...
New material
Router
Drill
Countersink
Well... I was considering using acrylic over a black mirror. I have the acrylic but where do i get a black mirror? I have a dremel with routing bits and a drill so I think I'll do fine with those tools and an x-acto knife
Reg
reguv760 is offline
post #4 of 7 (permalink) Old 03-06-2003, 06:48 PM
EKG
Try www.allparts.com for a wide variety of materials. They have the mirrored stuff, I think
EKG is offline
post #5 of 7 (permalink) Old 03-07-2003, 06:38 PM
I just tried routing acrylic with a dremel on its lowest speed,it melts.Instead I used a scroll saw at its lowest speed with good results.It definitely requires some patience.
musicdr is offline
post #6 of 7 (permalink) Old 03-07-2003, 06:43 PM
EKG
Even a scroll will melt your material....as you cut, the cut you just made melts back together behind the blade.
A table router would be best (hint :-) )
EKG is offline
post #7 of 7 (permalink) Old 03-08-2003, 08:01 PM
Hi eddie I'm using a table top scroll saw(variable speed) with a speed of 400.It doesn't melt the acrylic.In fact it works really good.I'll agree that any speed faster will melt your cuts back together.What speed are you using with your router?It is definitely a bit of work that goes into a pickguard.
musicdr is offline
WTB: mirror pickguard for UV777PBK Metallus Classified Ads: Guitars and Gear 7 04-28-2007 10:01 AM
WTB Mirror Pickguard AirGuitar Classified Ads: Guitars and Gear 1 05-21-2006 05:38 PM
How do you make the mirror pickguard look new? - Jem 7dbk shreddervai Ibanez JEM, UV, JS & Other Signature Models 6 11-12-2003 01:44 AM
Mirror finish??? - Is it easy or even possible to make... oodee Tech: Setup, Repairs and Mods 2 06-24-2001 04:35 PM
Mirror Pickguard? - ...for the UV777BK artoo Ibanez JEM, UV, JS & Other Signature Models 4 02-28-2001 02:04 PM
