How to remove RG output jack - Jemsite
post #1 of 3 (permalink) Old 07-19-2017, 07:36 AM Thread Starter
The jack socket on my RG550 is not functioning and I want to remove it to fix/change. The problem is that it requires some kind of wrench to unscrew the thin nut inside the cavity and I don't know what type of wrench or tool is required.
Can anyone point me in the right direction?
Ibanexor is offline
post #2 of 3 (permalink) Old 07-19-2017, 07:43 AM
taracatac's Avatar
Re: How to remove RG output jack
If memory serves, you need a 13mm wrench, but I have also used needle nose pliers.
taracatac is offline
post #3 of 3 (permalink) Old 07-19-2017, 08:15 AM Thread Starter
I managed to get it open just now using a wrench and needle nose pliers as advised. The 13mm was a touch too small on my one so had to use a 14mm which only just about fit.
Thanks for your help.
Ibanexor is offline
jack socket , wrench
Problem with my output jack..or something else? Smitty Gear, Equipment, Recording & Off Topic 0 12-10-2007 08:20 PM
Output Jack riconaka Tech: Setup, Repairs and Mods 0 03-16-2006 02:03 PM
Stereo output jack? Petie Pickups & wiring 1 05-03-2003 02:26 PM
Output Jack eg Pickups & wiring 1 12-26-2002 08:54 PM
A new output jack - Will any jack do? SalemB Tech: Setup, Repairs and Mods 6 02-02-2002 03:39 PM
