How to screw on a neck? - Jemsite
post #1 of 6 (permalink) Old 12-17-2009, 07:05 PM Thread Starter
Hi guys,
Well I bought a Jackson 24 fret neck for my project. I have a new body and for the life of me I cannot figure out how to screw on the neck accurately.
What is the best way to determine where to place the screws? This may seem like something simple, but I am burnt out from exams and I cant think straight right now with figuring out geometry. Anyways, thanks for the help.
manofthewild07 is offline
post #2 of 6 (permalink) Old 12-17-2009, 07:35 PM
Re: How to screw on a neck?
First of all this is my opinion and this is the way i do it
just exactly like you tighten your lug nuts on your vehicle...it doesnt really matter which screw goes in which hole, but tighten one (not all the way down) but just stop when you starts to see the neck suck up to the neck pocket then stop...hten tighten the next one the same way diagonally across from it..then the same way with the other two
this makes sure the neck is sucked up (parrallel) to the neck pocket well across the entire two surfaces (the neck surface and the neck pocket surface, where they meet..
hope this helps
kelmaur is offline
post #3 of 6 (permalink) Old 12-17-2009, 08:58 PM
elcid's Avatar
Balance is very important. If you get going to fast you will fall off, aside from that I imagine it would be just like screwing any place else.
elcid is offline
post #4 of 6 (permalink) Old 12-18-2009, 12:03 AM
Talking Re: How to screw on a neck?
ROTFLMAO
kelmaur is offline
post #5 of 6 (permalink) Old 12-18-2009, 04:54 AM
Put the neck into the neck pocket as far as it will go. If it hasnt already got holes in it, get a drill bit a few mm smaller than the neck screws you have, and tape it off at the length of the screws, so you dont drill too far. Then drill, and screw it on.
littlephil is offline
post #6 of 6 (permalink) Old 12-18-2009, 06:01 AM
axemanrio's Avatar
hope this helps
Heheh... kelmaur, be careful with your choice of words
axemanrio is offline
neck , project
Pickguard screw? waylay00 Tech: Setup, Repairs and Mods 20 05-29-2008 02:08 PM
Damaged Neck Screw Holes On My Body Eddie_V_H Tech: Setup, Repairs and Mods 10 04-11-2007 03:03 AM
Repairs to neck mounting screw holes mk50h Tech: Setup, Repairs and Mods 4 12-11-2006 01:14 PM
Retainer bar screw Fosse Fox Tech: Setup, Repairs and Mods 3 02-18-2006 04:28 PM
neck screws - neck screw positioning neverend Tech: Setup, Repairs and Mods 1 03-27-2002 03:11 PM
