How to tighten jack output? - Jemsite
post #1 of 9 (permalink) Old 05-14-2016, 02:02 PM Thread Starter
The jack outputs on my RG2120x is really loose. Not in the usually way, like loose from the guitar body, but it doesn't hold the jack cable really well and it keeps falling out all the time.
It's the big 'barrel' type output.
Any idea on how to solve this?
TruckstopChuckie is offline
post #2 of 9 (permalink) Old 05-15-2016, 12:26 PM
Re: How to tighten jack output?
You can put a piece of paper til it gets tight or super glue. Either way itīs an easy fix.
Tuga666 is offline
post #3 of 9 (permalink) Old 05-15-2016, 01:20 PM Thread Starter
This needs better explanation. Put paper in it?
post #4 of 9 (permalink) Old 05-15-2016, 01:29 PM
The spring clip inside the jack just isn't exerting enough pressure to keep the plug held firm. Just replace with a new jack, they're not expensive.
Rich is online
post #5 of 9 (permalink) Old 05-15-2016, 01:35 PM
I mean if the wood in the body isnīt enough to tighten the standard jack you have to increase the mass somehow... but Rich is probably right
Tuga666 is offline
post #6 of 9 (permalink) Old 05-15-2016, 01:37 PM Thread Starter
I know, but I was curious if it's an easy fix or not. Changing it is not a big thing, so I guess I'll look for a replacement. The weird thing is that both outputs is loose, not just the one for the humbuckers, but for the piezo too.
post #7 of 9 (permalink) Old 05-15-2016, 02:39 PM
I thought the gap was between the wood and the jack, if itīs in the jack itself... they have to be replaced ofc Itīs an easy fix nevertheless $$
Tuga666 is offline
post #8 of 9 (permalink) Old 07-07-2016, 01:17 PM
Oops, just seen there's a section for pickups and wiring, sorry if this shouldn't be here.
Hi All,
I have just bought a replacement jack for my 7v which i'm planning to replace soon.
With regard to the wiring, Is it a pretty straight forward job?
I can see 2 wires attached on the old one, but there are 3 tabs to solder to.
Is there anyway of identifying which tab is which?
Thanks
snakeman4968 is offline
post #9 of 9 (permalink) Old 07-08-2016, 09:05 AM
elcid's Avatar
http://www.cigarboxguitar.com/wp-con...-Annotated.jpg
Usually google helps
elcid is offline
What tool to tighten the input jack - Ibanez RG's beyblade Tech: Setup, Repairs and Mods 17 06-23-2010 09:53 PM
Tighten 99 Universe input jack? ChaNce Ibanez JEM, UV, JS & Other Signature Models 4 05-18-2006 03:50 AM
Output Jack riconaka Tech: Setup, Repairs and Mods 0 03-16-2006 02:03 PM
Output Jack eg Pickups & wiring 1 12-26-2002 08:54 PM
A new output jack - Will any jack do? SalemB Tech: Setup, Repairs and Mods 6 02-02-2002 03:39 PM
