How it works? - Jemsite
post #1 of 7 (permalink) Old 06-21-2005, 11:30 PM Thread Starter
How it works?
Hi guys...
I have always been a big fan of the H/S/S configuration, but now that i have acquired a RG 1570 i think that the neck humbucker gives lots of versatility, however, lacks of that fat ,kind of """"""percussive"""""" sound of the single p'up ...
Then i heard about the coil spliting mode (i know, i know, what a retard... it has been there for a long time, but i didnt have any idea!) and i wanted to ask you guys, how that thing works? how can i instal that thing on my guitar? can you "split" any humbucker out there?, and most importantly, does it sound like a real Single coil when is splited?????
Thanks guys
dangomles is offline
post #2 of 7 (permalink) Old 06-22-2005, 10:57 AM Thread Starter
Re: How it works?
anyone....?
post #3 of 7 (permalink) Old 06-22-2005, 12:16 PM
Re: How it works?
Coil splitting only works on 4 wire conductor humbuckers. Essentially all your doing is shorting one coil of the pickup so it's no longer wired in series or parallel to the other coil. You can install a coil tap to split a humbucker on any guitar, you just need to replace either the volume pot or tone pot with a push-pull pot and wire it accordingly. (or you could install a mini toggle switch).
As for sound, your mileage will vary here. Some humbuckers sound better in single coil configuration than others. Why not try a Dimarzio Humbucker from hell?? It's a humbucker that sounds like a single coil(with the output of a humbucker)
buddroyce is offline
post #4 of 7 (permalink) Old 06-22-2005, 05:08 PM Thread Starter
Re: How it works?
Thanks for your answer...
the thing about the humbucker from hell is that it haves soooooooooooo much treble, lacks of warmness , i was thinking in spliting the seymour duncan jazz model (on neck position) , what about this pickup?
Where can i purchase the coil tap?
post #5 of 7 (permalink) Old 06-22-2005, 07:17 PM
Re: How it works?
Just ask your local guitar shop for a push-pull volume/tone pot (whatever you prefer). Any online supplier should offer them, too.
It should look like this:
http://www.has-sound.com/product_ima...h-Pull_Pot.jpg
Another easy mod would be to use the switch for switching off your middle pickup; then you'll get just the inner coils of the humbuckers in positions 2 and 4.
horstausmforst is offline
post #6 of 7 (permalink) Old 06-23-2005, 09:58 AM Thread Starter
Re: How it works?
ok, thanks for your help!
post #7 of 7 (permalink) Old 06-23-2005, 10:42 AM
Re: How it works?
As far as I know you wont have to add an actual switch just rewire it so the neck pickup in the 4th postion is the only pickup selected
sniperfrommars1 is offline
coil split , coil splitting , coil tap , guitar shop , inner coils , local guitar shop , mini toggle , neck humbucker , neck pickup , neck position , seymour duncan , seymour duncan jazz , toggle switch
I don't know how....but it works! wandereruk05 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 09-15-2010 04:34 PM
Works in progress Martyr Machine Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 4 09-04-2007 12:56 AM
IT WORKS!!! FINALLY!! cusplaya All Other Guitars (including Prestige) 0 05-31-2004 10:24 PM
Jem-POD, works like a charm? ShReD404 Ibanez JEM, UV, JS & Other Signature Models 24 01-27-2003 08:36 AM
