How would I go about removing this? - Jemsite
post #1 of 5 (permalink) Old 05-11-2010, 05:29 PM Thread Starter
http://i44.tinypic.com/1j439g.jpg
It's literally stuck in there. There's not enough sticking out to grip with anything. I'm getting really frustrated.
Kwirk is offline
post #2 of 5 (permalink) Old 05-11-2010, 05:55 PM
Re: How would I go about removing this?
A set of screw extractors would probably do the trick - reverse, bite-threaded or the square variety, either type would probably get a bite in there, and let you back that out.
steve is offline
post #3 of 5 (permalink) Old 05-11-2010, 05:57 PM
CosmicDebris's Avatar
Two Options:
1. Grenade - Potential collateral damage but will work.
2. Go to hardware/Tool store and get a easy out.
http://www.homedepot.com/webapp/wcs/...d&ddkey=Search
CosmicDebris is offline
post #4 of 5 (permalink) Old 05-21-2010, 03:48 PM Thread Starter
I got it out! Thanks for the tips. Screw extractors didn't do the trick, but they helped. I had to drill the stud with a 1/8" drill bit before I could get a grip with the screw extractors. Once I got that in, it wasn't going anywhere after a certain point. I finally (and by accident!) pulled out the whole stud, with the stud holder and all, out of the guitar. I used a dremel to cut slits in the side of the stud so that I could try unscrewing it with a screw driver. I tried this when the stud was still in the guitar, but couldn't get close enough without damaging the finish on my guitar. I ended up using a knife to unscrew it. The guitar has a few battle scars, unfortunately. Though nothing serious.
Whew. That thing was seriously not going to go easy.
http://i48.tinypic.com/1z52i5w.jpg
Kwirk is offline
post #5 of 5 (permalink) Old 06-07-2010, 01:05 PM
great....
fbonito is offline
Removing pickups MFB Pickups & wiring 5 09-21-2008 12:27 AM
Removing Stickers kotornut Tech: Setup, Repairs and Mods 6 01-04-2008 09:37 AM
Removing Tone Pot MrChadley Tech: Setup, Repairs and Mods 0 02-13-2006 03:17 AM
removing a spring? wastedyears Ibanez JEM, UV, JS & Other Signature Models 2 08-06-2005 07:03 AM
Removing the EMG 81-7's from my SC-607B shredfingers Tech: Setup, Repairs and Mods 7 03-27-2004 10:09 PM
