i need to lessen the low end when neck p-up is toggled on. - Jemsite
post #1 of 3 (permalink) Old 03-26-2004, 02:19 PM Thread Starter
I notice that on my Js1000's, when i toggle to the neck pickup, there is a bit too much bass/low end in the tone, and not enough mid/high frequencies cutting through.
Is there a way to lessen the low end when the neck pickup is immediately engaged, without having to engage the high pass filter and then lowering the volume?
I'd like to be able to just toggle the neck pup and be done with it.........i need better balance b/n low and mid/highs.......the low end is a bit overpowering.
Thanks in advance!
SilverSurfer2 is offline
post #2 of 3 (permalink) Old 03-26-2004, 02:57 PM
Try lowering the pickup away from the strings a bit, and/or individually backing off the pole pieces on the lower strings. If the pickup is too close to the strings, sometimes you'll get a signal that's too hot and muddy.
darren wilson is offline
post #3 of 3 (permalink) Old 03-26-2004, 05:43 PM Thread Starter
is there a standard height for the neck and bridge pickups that ibanez goes by? And how about the height of the pole pieces?
I'll try lowering the bass side of the pickup and see what happens!!
bridge pickup , bridge pickups , high pass filter , lower strings , neck pickup , neck pup
Richie Kotzen's Electric Joy neck pickup, Ibz RBM pickguard & 1966 Fender Neck Plate mayzan Classified Ads: Guitars and Gear 0 11-30-2010 10:04 AM
FS: RG550 Maple neck/Edge Trem, Jackson neck, Dimarzio pups NickCormier Classified Ads: Guitars and Gear 10 01-08-2010 12:46 PM
Flamed jackson neck, birdseye musikraft neck, loaded strat body shesky Classified Ads: Guitars and Gear 2 04-30-2009 06:02 PM
SWAP: Jem neck 77FP tree of life and floral head for 777DY pyramid neck blitzmark1 Classified Ads: Guitars and Gear 2 03-19-2009 06:41 PM
ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only) 7-request Pickups & wiring 2 07-05-2005 11:18 AM
