I need wireing help - new pickups in my rg7621 - Jemsite
post #1 of 4 (permalink) Old 06-13-2001, 10:00 PM Thread Starter
I'm still working on my customized rg7621 well I got a new set of pickups ( a dimarzio tonezone 7 and a paf 7) and need to wire it up. I want to get rid for the tone control and use it and the vol. control as two independent vol. controls ( one for each pickup) So its two humbuckers two vol.s a five way switch to the output. Now can any one out there tell me how to wire this up ( if you could draw me a pic that one help allot) or does any one know where to find the wiring diagram for a stock rg7621 so I can work from there? :help:
jem7pbk is offline
post #2 of 4 (permalink) Old 06-13-2001, 10:14 PM
I need wireing help
Here is the original wiring diagram from Ibanez...
http://www.ibanez.com/wiring/W97051.GIF
This may be helpful, but it seems to only work well with either the neck or bridge positions (the middle ones aren't very exciting)...
http://www.guitarnuts.com/wiring/twovol.html
(Edited by bachle7 at 9:21 pm on June 13, 2001)
bachle7 is offline
post #3 of 4 (permalink) Old 06-13-2001, 10:19 PM Thread Starter
I need wireing help
Thanks! ( duh I should have looked there) If any one can tell me how to turn the tone to a vol let me *know
jem7pbk is offline
post #4 of 4 (permalink) Old 06-13-2001, 10:36 PM
I need wireing help
If you truly want two seperate volumes, you'll have to change the volume pot wiring too. Otherwise when you have both pickups on you will be drawing the volume of both down to ground as you move one pot or the other. Like on a jazz bass, you will switch the "pickup hot" with the "output hot". *Really that means switching the middle lug with the end lug, and leaving the ground where it is. *This way, when you turn the pot down, you are bleeding the pickup to ground, not the combined hot to ground, and they both work independently and can be brought all the way down without killing off the other one.
frankfalbo is offline
bridge position , dimarzio tone , dimarzio tonezone , wiring diagram
RG7621 stock pickups WAY too hot! BlanK Pickups & wiring 1 11-21-2012 05:50 PM
For Sale: 1999 Ibanez RG7621 w/DiMarzio pickups Megadeth7684 Classified Ads: Guitars and Gear 3 08-05-2010 11:11 PM
FS: rg517 guitar - rg7621 Neck - evo paf & paf pro pickups & pickguards zar7 Classified Ads: Guitars and Gear 4 08-05-2008 11:33 AM
FS: Dimarzio, PRS pickups, RG7621 neck and RG7421 body dookie_cookiez Classified Ads: Guitars and Gear 13 10-03-2006 07:47 PM
wireing help! jemman7blue Pickups & wiring 4 06-20-2005 05:59 PM
