Ibanes RG320 lock and tremelo problem!!!! - Jemsite
post #1 of 4 (permalink) Old 05-02-2004, 11:11 PM Thread Starter
in got this Ibanez RG 320, and the strings slip out of where they're pinched by the string holder block. what do i need to do? are the string supposed to be put in their some special way?? thanks so much
folkrockmonica is offline
post #2 of 4 (permalink) Old 05-02-2004, 11:17 PM
First make sure there isn't a stub of another broken string in there and that's why you're not getting good grip. If not pull the block out and look for a groove cut in it [by the string], if so grind it flush again.
Rich is offline
post #3 of 4 (permalink) Old 05-03-2004, 02:46 AM
My TRS's strings started popping out of the trem after hte first string change and no matter how gentle I was, and eventually how tight I got it, it would always happen.
The metal is just too soft and ****ty, at least on mine, to hold the strings.I think I just got a really bad one, but in the end I had to replace my trem. If it's new, return it. If it's old, then you have a few options.
1. Put an OFR in it.
2. Do a bit of work, put an Edge in it.
3. Take out the lock block and hte screw you use to tighten it and feed the ball end of the string through the screw hole.
Assuming you're not talking about the locking nut...
Either way, if you're poor/broke, option 3 will work. If you want to make a good investment, go with 1 or 2 when you can afford it.
DirtyBird31 is offline
post #4 of 4 (permalink) Old 05-03-2004, 06:04 PM Thread Starter
thanks so much, u guys helped a lot
locking nut
Replacing Dimarzio Clip Lock With Dunlop Strap Lock EEF13 Gear, Equipment, Recording & Off Topic 3 12-20-2011 05:51 AM
Floyd Rose String lock problem. Pulsar Gear, Equipment, Recording & Off Topic 3 03-24-2009 10:13 PM
JEMV tremelo spring problem JS Vai Tech: Setup, Repairs and Mods 14 10-01-2003 05:12 AM
Trem adjutment problem--block lock inerference gkelm Tech: Setup, Repairs and Mods 16 10-08-2002 09:48 PM
Lock nut problem - need advice deadly damien All Other Guitars (including Prestige) 2 11-10-2001 01:19 PM
