Ibanez LO TRS II replacement trem - Jemsite
post #1 of 10 (permalink) Old 07-09-2010, 10:17 PM Thread Starter
K, so this is my first post, and i've looked all over this site but couldn't find a difinitive answer. k, so i was given a 2000 Ibanez JEM555 from my friend because he had no more use to it. He said the only problem with it was the tremolo, after heavy use, it will not stay in tune. So i brought it to my local gutiar shop for a complete setup and i will admit that it did stay in tune for about 2 or 3 hours of heavy use, but will eventually go flat. i am sick and tired of this peice of s**t trem. So my question is does anyone know a quality bridge that could replace this, with minimal or no routing??? (Ibanez Lo-Trs Trem II)
Steve Vai's Kid is offline
post #2 of 10 (permalink) Old 07-10-2010, 01:28 AM
Reviews: 120
Re: Ibanez LO TRS II replacement trem
It's talked about all over this site, so I don't know how you missed it in search.
In saying that the Gotoh will fit with little to no routing. It's a fantastic trem too. Change out the old studs and anchors and replace with the high quality Gotoh locking units. The LO-TRS II studs are half the problem with tuning stability.
LonePhantom is offline
post #3 of 10 (permalink) Old 07-10-2010, 06:25 AM
+1
Get some descent studs, new springs and you might be ok.
nafigator is offline
post #4 of 10 (permalink) Old 07-10-2010, 08:08 AM
Reviews: 120
Originally Posted by nafigator View Post
+1
I doubt it. When I said the LO-TRS II studs were half the problem, the other half I didn't mention were the knife edges on the LO-TRS II. Both will go about the same time.
Buy a Gotoh licensed FR, and make sure you replace the studs and anchors too. If it's not a job you can do yourself pay someone to do it. Just replacing the trem sans studs is only half the job, and you'll still have tuning instability issues.
post #5 of 10 (permalink) Old 07-10-2010, 01:06 PM Thread Starter
thanks very much, i was hoping to put an OFR in but if a gotoh will work better then i will probably try that. thanks for your input.
post #6 of 10 (permalink) Old 07-10-2010, 02:06 PM
Reviews: 98
Here's a great option with minimal routing--it's very easy to do with just a Dremel and router bit:
http://projectguitar.com/tut/trs2lopro.htm
AlaskaBat is offline
post #7 of 10 (permalink) Old 07-10-2010, 04:38 PM
Including studs and anchors?
Melek Taus is offline
post #8 of 10 (permalink) Old 07-10-2010, 05:27 PM
Reviews: 120
No. The trem should fit in the route, but you will have to pull out the old anchors and make the holes larger to accommodate the larger Gotoh ones. Well worth it though.
post #9 of 10 (permalink) Old 07-12-2010, 06:18 PM Thread Starter
thanks AlaskaBat, i think i will try that option
post #10 of 10 (permalink) Old 07-13-2010, 09:28 AM
Reviews: 6
Just be careful with the finish -- the guy doing the work on the link posted above is doing it on an oil-finished body. If you're not careful, you can chip the finish on something like a Jem. A good sharp bit and a steady hand are key.
Philboski is offline
lo trs ii
Question for ZR trem experts // replacement trem arm dariusvara Tech: Setup, Repairs and Mods 2 07-09-2010 01:50 AM
Replacement Trem DannyB819 All Other Guitars (including Prestige) 1 03-02-2009 04:25 PM
replacement trem humpy All Other Guitars (including Prestige) 4 10-29-2008 10:30 AM
Ibanez Edge trem bar replacement? Clydefrog All Other Guitars (including Prestige) 6 08-12-2006 10:56 PM
replacement trem thc303 Tech: Setup, Repairs and Mods 7 03-05-2003 04:20 PM
