Ibanez RG320DXQM trem replacement? - Jemsite
post #1 of 5 (permalink) Old 02-08-2011, 08:12 PM Thread Starter
I've got an oldish mid-range Ibanez RG 320 DXQM. I've replaced the pickups, and now the only thing holding it back is the trem system. Lo-Trs II bridge sucks, worn out long ago, and doesn't keep itself at the zero point. I've been told that an Original Floyd Rose, Gotoh Floyd Rose, or (maybe Schaller FR) will fit, but I don't want to invest in one until I'm 100% sure what to buy. Here are links to where to buy the three, can someone tell me which will work?
http://www.beyondeleven.com/Gotoh-re...floyd-rose.htm
http://www.beyondeleven.com/Original...l-frt100-c.htm
http://www.warmoth.com/%2FOriginal-Floyd-Rose-C693.aspx
Hopefully Gotoh works? It's least expensive.
mwmax is offline
post #2 of 5 (permalink) Old 02-08-2011, 09:29 PM
Reviews: 120
Re: Ibanez RG320DXQM trem replacement?
The SEARCH tool will unveil a plethora of Information on swapping out the LO-TRS II trem.
Have a look further down the first page of the tech section to the RG470 trem replacement thread. There's a ton of info there.
LonePhantom is offline
post #3 of 5 (permalink) Old 02-08-2011, 10:27 PM
OFL and Gotoh will fit. i would get the Gotoh, it has locking posts and a brass block. You will have to remove the original trem anchors and drill the holes out a little to install the locking anchors and posts. If you decide to use the originals you can sell the locking post/anchor set for about 40 bucks.
moonlight is offline
post #4 of 5 (permalink) Old 02-09-2011, 12:55 AM Thread Starter
I've got an option for a nut to come with it, asks me for a radius.. I measure 1 11/16" width on my nut, does that seem right? The 1 5/8" nut is no extra charge. I may have just measured long. Also, is there any reason not to use my existing nut?
mwmax is offline
post #5 of 5 (permalink) Old 02-09-2011, 02:11 AM
Reviews: 120
Again, did you go and read the thread I pointed you to? All the info is there.
Again as I (and others) said in that thread, stick with the Ibanez nut. If it's worn get a new one, or use the pads from the nut provided with the trem.
Seriously, go read the RG 470 trem replacement thread further down the first page. EVERYTHING you would want to know is there, as well as many other threads posted on this site. USE the SEARCH.
bridge , floyd rose , lo trs ii , tremolo , whammy
Ibanez LO TRS II replacement trem Steve Vai's Kid Tech: Setup, Repairs and Mods 9 07-13-2010 09:28 AM
Ibanez RG320DXQM have a good trem? IBNZ_RG All Other Guitars (including Prestige) 5 06-09-2010 02:54 PM
FS/FT: Ibanez RG320DXQM Dave67 Classified Ads: Guitars and Gear 0 01-17-2008 09:44 PM
Ibanez Rg320DXQM, Line 6 Guitarport & Uber Metal w0lv3121n3 Classified Ads: Guitars and Gear 5 08-21-2006 08:33 PM
Ibanez Edge trem bar replacement? Clydefrog All Other Guitars (including Prestige) 6 08-12-2006 10:56 PM
