Ibanez S470 help - Jemsite
post #1 of 6 (permalink) Old 01-30-2011, 08:23 PM Thread Starter
Ibanez S470 help
I have an Ibanez S470 from the late 90's. It has a TRS TREM on it. I would like to replace it with a better system. I haven't had much luck searching for answers for what might be compatible. The engraving reads TRS TREM not lo-TRS Trem. Are these different models because my google searches usually only bring results for the lo-TRS. What are your suggestions.
Secondly, is it possible to change out the neck for a 24 fret neck instead of the 22?
mboss77 is offline
post #2 of 6 (permalink) Old 01-30-2011, 09:05 PM
Reviews: 98
Re: Ibanez S470 help
TRS 101, TRS, Lo TRS, Lo TRS II
AlaskaBat is offline
post #3 of 6 (permalink) Old 01-30-2011, 09:06 PM
You can change the trem out pretty easily, I believe an OFR or Gotoh floyd rose will fit fine.
Unfortunately you can't get a 24 fret neck for a guitar built as a 22. The intonation will be way off. Of course, in my case I think thats more than compensated for by the fact that the neck pickup on a 22 sounds so much sweeter.
GuitarBizarre is offline
post #4 of 6 (permalink) Old 01-30-2011, 10:04 PM Thread Starter
I looked up the Gotoh and I was wondering if there was a particular size that I should order?
mboss77 is offline
post #5 of 6 (permalink) Old 01-30-2011, 10:49 PM
Reviews: 120
From memory there is only one size.
LonePhantom is offline
post #6 of 6 (permalink) Old 01-30-2011, 10:57 PM Thread Starter
sorry I should have been more specific. I meant the string nut size. there are several options and I'm not technical enough to know.
mboss77 is offline
ibanez s470 help
Similar Searches
FS Ibanez s470 Made in Japan! Like New with SKB/Ibanez Hardshell Case - $399 Shipped CA_Dan Classified Ads: Guitars and Gear 7 11-21-2008 01:43 PM
1991 Ibanez 540S7 and 2003 Ibanez S470 Sevenstringer Classified Ads: Guitars and Gear 14 07-06-2008 10:53 AM
FT: Ibanez S470 GiS Classified Ads: Guitars and Gear 2 10-23-2006 10:21 PM
FS: ibanez s470 RRAShred Classified Ads: Guitars and Gear 1 08-18-2006 07:03 PM
FS: Ibanez S470 RRAShred Classified Ads: Guitars and Gear 9 08-07-2006 07:27 PM
