Insert piezo in edge pro saddle - Jemsite
post #1 of 5 (permalink) Old 04-27-2018, 01:25 PM Thread Starter
Hi,
I succesfully removed the metal "sound chip" as per Rich advice in http://www.jemsite.com/forums/f21/re...ro-161185.html but now I need to install the piezo inserts. It haven't been easy to put them correctly, they tend to enter uneven.
Any tip to make it easier? Perhaps with vaseline, wd40 or similar?
hmoller is offline
post #2 of 5 (permalink) Old 04-27-2018, 06:31 PM
Re: Insert piezo in edge pro saddle
Shotgunn Mods used to do this regularly, but never shared how to do it.
Rich is offline
post #3 of 5 (permalink) Old 04-28-2018, 09:31 AM
I did this once. I feel like there was a tendency for them to go in crooked, but I think I just popped it out and tried again. Make sure that after you press out the hardened metal inserts that you clean out any adhesive that's left over.
Takin' a Ride is offline
post #4 of 5 (permalink) Old 04-28-2018, 03:52 PM
Originally Posted by hmoller View Post
Hi,
How about the conductive grease used for mounting heat sinks on CPUs.
snaggleyoda is offline
post #5 of 5 (permalink) Old 05-02-2018, 10:58 AM Thread Starter
Thanks to everyone, what I did at the end was to use liquid vaseline (I believe that at the end it wasn't necessary) and put it in the hole from the saddle. After that, I put the insert, w/o force, taking care that it stays horizontally. Then with a clamp (like the one that @Rich uses here IBANEZ RULES Clean and Setup) I pressed the inserts aggain the saddle, take care not to damage the cable from the piezo.
I'm doing a small mod, w/o preamp. I go from the summing board (wich sums all of the piezos signal together) directly into the connector. Mine guitar came with a TRS (or stereo) connector so no need to change, T is for magnetic and R for piezo. As long as you use a high impedance preamp, it works fine, or you could use an external preamp or DI box for that.
Why piezos need preamps is because they act as capacitor, so if the impedance of the preamp isn't high enough, you end up with a highpass filter, removing the lower signals. Normal mixers doesn't have high impedance so DI box or preamp is needed.
Since I have a pod HD 500x which has 2 inputs (guitar and aux) I wan to use ine for guitar and one for piezo and do all of he changes between them there (even blending could be possible).
hmoller is offline
chip , edge pro , mod , piezo , sound chip
Ibanez Lo-Pro Edge Piezo Bridge + Piezo PCB atticus1088 Classified Ads: Guitars and Gear 2 03-28-2015 10:59 PM
edge or edge pro trem insert size 7/16 rizzobx Tech: Setup, Repairs and Mods 6 08-27-2009 10:22 AM
edge or edge pro trem insert size 7/16 rizzobx Tech: Setup, Repairs and Mods 0 08-25-2009 11:29 PM
Edge Pro 2 plastic arm insert? musicmanrod Tech: Setup, Repairs and Mods 2 03-21-2004 02:47 PM
edge pro saddle insert problems The Madness Here Tech: Setup, Repairs and Mods 8 12-31-2003 09:01 PM
