The inside of a RG450DX - help with parts please! :) - Jemsite
post #1 of 8 (permalink) Old 02-10-2012, 04:13 PM Thread Starter
So ive have this guitar for abt 12years, and finally got round to cleaning it! :P
took the pickguard off, and was pleased to find that the cavity was painted with shielding paint!
had a look at the wiring etc, as im looking at upgrading the pups etc in the near future, and this is what i could see:
my questions are:
what switch have i got? the only marking i could see was "cortec"
the pups only seem to have one wire coming from them - if i was to upgrade, would the switch support the 4 wires that more dimarzios seem to have?
what is the green capacitor on the tone pot? is that stock on all MIJ ibbys?
thanks
rich
rickybaby1985 is offline
post #2 of 8 (permalink) Old 02-10-2012, 04:27 PM
Re: The inside of a RG450DX - help with parts please! :)
Each pickup on your Ibanez has two wires running to the switch, Red and White.
They also have a ground going to the back of the pot.
A real 5 wire Dimarzio will go like this.
Bare wire and Green to back of the pot.
Red wire to the spot on the switch where the white wire is.
Black and White wires to th spot on the switch where the Red wire is.
When you hook up your single coil it could very a little depending on what single coil you buy, if you change it out.
sebastian is offline
post #3 of 8 (permalink) Old 02-10-2012, 04:29 PM
RGTFanatic's Avatar
Your Hums have 3 wires inside the larger shield (red/neck grn/bridge) each one has:
red= hot output
white= coil tap
bare= ground
Your switch is part#3PS1CGAE5. It will work fine with your dimarzios
the cap determines the cutoff point for the tone knob.....it's on all Ibby's (and all other guitars)
RGTFanatic is offline
post #4 of 8 (permalink) Old 02-10-2012, 04:48 PM
red= hot output
white= coil tap
bare= ground
That is what I did with mine.
I think I have the Red and White mixed because the volume won't roll off, it just cuts off.
That is why I am thinking the opposite of what your saying would be correct.
post #5 of 8 (permalink) Old 02-10-2012, 04:55 PM Thread Starter
ok wicked! thanks guys!
would there be any significant improvement in upgrading the switch? - i dont want any set up other than how it already works - no funky series or parallel stuff going on! :P
post #6 of 8 (permalink) Old 02-10-2012, 05:25 PM
RGTFanatic's Avatar
Other than longevity, there's no real advantage to a better quality switch. These cheaper switches are easier to overheat when soldering, but if your careful you should have no problems. If you want something simple, sturdy, and long lasting.....get a fender 5-way for strats. They're tough as tanks and easy to work with.
post #7 of 8 (permalink) Old 02-11-2012, 05:49 AM
if you are looking to upgrade its probably a good idea to think about the pots,
often they get scratchy or crackly after about 10 years, and they are easy and cheap to replace.
wont make any difference to the tone but it will be annoying if they get stiff or noisy in a year or so.
LostInRockFormations is offline
post #8 of 8 (permalink) Old 02-11-2012, 07:07 AM Thread Starter
i think they're already a bit stiff, and the vol is definitely a bit scratchy already!
but my plan was to change them out when i did the pickups!
2001 rg450DX seanrg All Other Guitars (including Prestige) 0 11-27-2011 09:03 AM
rg450dx in Lazer Blue? jbouxa All Other Guitars (including Prestige) 10 01-01-2011 04:53 PM
RG450DX Complete Body and Neck Parts TAorama Classified Ads: Guitars and Gear 6 06-19-2005 09:20 PM
pic of my RG450dx with mods done JimmyJ All Other Guitars (including Prestige) 6 08-11-2004 02:03 AM
WOW! Best improvement to my RG450dx EVER!!!!! JimmyJ All Other Guitars (including Prestige) 7 01-18-2004 06:42 PM
