Intonation help needed on my Ibanez RG570 - Jemsite
post #1 of 12 (permalink) Old 01-21-2004, 02:49 AM Thread Starter
Hey dudes,
i gots a problem, my high E string, if i fret a note, say F# (2nd fret) and put distortion on it beats (wowowowowowowo)
if i hit the D note (10 fret) it beats quicker, and sounds slightly out of tune,
i thought intonation, so i checked the harmonic at the 12th and its fine, i checked the open E in the tuner, it too is fine, i checked the fretted E (12) and it was in tune but oscilating, then i checked the open E and although the tuner said its in, it had a beat to it still...wowowowowowowow....
another problem with the intonation is that the Saddle is as far forward as it can go, i think if i could shift it forward slightly it would be ok but i cant :S the only thing i can do is change my High E every 2 months, which does fix it...for a while
ive included a soundclip and a pic of the setup, at the end of the soundclip i compare the E (12e) to the E on the B (17) you can hear how the B string E is smooth where my 12th is yuk... any clues for other adjustments? Ps im not sure if this bridge is an original Edge or a LO PRO, can someone tell ?
cheers Jim
pic
sound clip
http://members.dodo.com.au/jjer/tuning.mp3
JimmyJ is offline
post #2 of 12 (permalink) Old 01-21-2004, 02:53 AM
Has it always done that? If not, it may be your strings need changing. Even if it's a new set, you may have gotten a bad batch.
LoverMan is offline
post #3 of 12 (permalink) Old 01-21-2004, 03:00 AM
Re: Intonation help needed on my Ibanez RG570
Strings get worn over time, and the intonation slips more and more the longer they're played.. 2 months is a long time out of one set of strings, be happy. Mine last 2-3 weeks, then they're gone..
BTW, you should only set your intonation with a brand new set of strings.
toshiro is offline
post #4 of 12 (permalink) Old 01-21-2004, 03:04 AM Thread Starter
just changed strings and had a think about it, its actually closer to 4-5 months ( time flies ) but i just changed my high E and have a listen, problem is gone,
http://members.dodo.com.au/jjer/intune.mp3
JimmyJ is offline
post #5 of 12 (permalink) Old 01-21-2004, 03:11 AM Thread Starter
just one last thing, lucky i bought 3 e strings today should last me til may/june
JimmyJ is offline
post #6 of 12 (permalink) Old 01-21-2004, 06:46 AM
Jimmy,
get yourself used to check the intonation at 24th fret, or at 22nd fret if it's a 22-fret guitar.
nuno is offline
post #7 of 12 (permalink) Old 01-21-2004, 07:21 PM
Originally Posted by nuno
Jimmy,
Werd...
And if you want, match your trem to this. This is the secret Rich setup...
http://www.x-velocity.com/ebay/edge.jpg
Timanator is offline
post #8 of 12 (permalink) Old 01-21-2004, 07:23 PM
Lo-Pro Edge
Vaibanez is offline
post #9 of 12 (permalink) Old 01-21-2004, 07:24 PM
Jimmy,
Werd...
That's just a great starting spot, it still has to be fine tuned, to the last fret of course
Rich is offline
post #10 of 12 (permalink) Old 01-21-2004, 07:30 PM
Thats what a Meant RIch, but on all the Guitar's I have setup, thei way pretty much does the job right off the bat. Now I just need to make a template...
post #11 of 12 (permalink) Old 01-21-2004, 07:34 PM
That would assume every guitar intonates exactly the same, and, every set of stud inserts is in exactly the same spot, not good to assume
Rich is offline
post #12 of 12 (permalink) Old 01-22-2004, 04:10 AM
Originally Posted by Rich
That would assume every set of stud inserts is in exactly the same spot...
i wish they were!
nuno is offline
fret guitar , pro edge
Intonation on a rg570 Drastion Tech: Setup, Repairs and Mods 7 12-18-2012 01:51 AM
Help needed! RG570 w Fender dm50 switch Jibboom77 Pickups & wiring 11 09-01-2009 05:46 PM
needed - intonation lock screw :) Devon8822 Classified Ads: Ibanez JEM/UV Guitars 2 03-13-2008 11:18 AM
ibanez intonation tool ajdehoogh Gear, Equipment, Recording & Off Topic 9 12-26-2003 05:31 PM
Can I adjust the intonation without the intonation tools? - cowcowcow Tech: Setup, Repairs and Mods 3 01-15-2002 03:11 PM
