Intonation problem - Jemsite
post #1 of 3 (permalink) Old 10-10-2011, 08:22 AM Thread Starter
Intonation problem
I am having a problem with my Edge tremolo. When I am trying to intonate it properly, the back of the string lock bolt hits the body when pulling up. It only allows me 3 semitones on the e string and 1 on the high e. I know that there is no real way to fix this, but I just have to say, Ibanez, if you make a tremolo you should make the cavity long enough to ensure normal intonation. It isn't even at the max. there would be 2-3mm movement more possible.
TheFreak777 is offline
post #2 of 3 (permalink) Old 10-10-2011, 08:56 AM
Re: Intonation problem
Shim the neck and raise the tremolo - that's what I would do.
The Euphor is offline
post #3 of 3 (permalink) Old 10-18-2011, 11:28 AM
Re-route the cavity. Or cut some of the string lock bolt off. Or order a new shorter bolt. Try mcmaster dot com.
shotgunn is offline
cavity , edge , intonation
intonation problem on my 550 ftw1422 Tech: Setup, Repairs and Mods 17 12-17-2010 04:04 PM
Bad intonation problem, please help. ChopDuel Tech: Setup, Repairs and Mods 12 12-06-2010 06:19 AM
intonation problem griever88 Tech: Setup, Repairs and Mods 6 10-27-2009 02:52 PM
A problem with '89 FP intonation. Ad_Astra Tech: Setup, Repairs and Mods 12 09-27-2007 02:15 AM
intonation problem mr.jem555 Tech: Setup, Repairs and Mods 3 05-29-2007 03:02 AM
