intonation/ trem level question - Jemsite
post #1 of 2 (permalink) Old 08-07-2011, 09:40 PM Thread Starter
i just got my guitar back and i am not happy with the set up. the edge bridge is not level in the cavity, it is tilted back.... will adjusting the spring tension to level the bridge result in messing up my action (make it higher). If i adjust the spring tension will i need to lower the bridge at the studs? will my intonation be off if i do this? i waited way too long to get the guitar back from the shop so i am hesitant to ship it back there.....
thanks for the advice.
scottop1972 is offline
post #2 of 2 (permalink) Old 08-08-2011, 06:55 AM
Re: intonation/ trem level question
Back the screws out of the spring clip a little and retune. Repeat until the tremolo is level. This will not screw up intonation, but it may raise the action just a bit. If you aren't happy with the action, lower the tremolo using the studs and retune.
gideond is offline
intonation , trem level
Lo-Pro Edge Trem - intonation problems gbibanez Tech: Setup, Repairs and Mods 8 08-05-2008 11:35 PM
setting the trem level when tuning down half a step John Finn Tech: Setup, Repairs and Mods 2 10-01-2006 12:26 PM
Trem float level Ant1981 Tech: Setup, Repairs and Mods 4 09-29-2006 08:17 PM
About intonation and trem angle Yō_Kun Tech: Setup, Repairs and Mods 6 05-08-2003 02:55 AM
Lo-Pro Edge Trem Level? - Does the trem need to be level wit Dean Southcombe Tech: Setup, Repairs and Mods 5 06-11-2001 09:09 PM
